F1 Evaluating ‘Wheel Arches’
648
Re: F1 Evaluating ‘Wheel Arches’
Just_a_fan wrote:
18 Sep 2023, 17:17
Just_a_fan wrote:
18 Sep 2023, 16:16
... It happens on road cars too and their tyres are cold, especially in wet weather.
... not enough to cause significant enough evaporation to create a dry line behind the car. The vastly more significant way that standing water is removed from the track is physically moving it with the tyre...
road or track the tyres of each speeding car are a 100+ kW 'hair dryer' acting on one part of the road surface
'drying' ie reducing in various ways the suspended liquid water aka spray by heating the 'physically moved' water
ie the notional moving effect doesn't occur without the effects of that heat occurring
plus F1 wheel aerodynamic drag will also heat local air (maybe 50 kW) - and heat it by brake cooling (maybe 200 kW)
all the above mechanisms present as 'standing water physically moved with the tyre'
mzso
mzso
65
Tommy Cookers wrote:
20 Sep 2023, 13:59
Just_a_fan wrote:
18 Sep 2023, 17:17
Just_a_fan wrote:
18 Sep 2023, 16:16
What's your point? Yes the tires heat up, but also it's irrelevant. The massive amounts.of water soak up the heat easily. Water is also one of the highest heat capacity substances known.
Ferrari is testing latest version of "wheel arches" for extreme wet tyres today. At this point it's not even funny, these are full wheel covers probably tested to see if even the most extreme cover solution would work. It doesn't
SharkY
SharkY
Vanja #66 wrote:
09 May 2024, 10:10
Well, TBH the spray behind the car with covers looks slightly diminished compared with another, however it's hard to judge, given how close the cars were.
With the amount of air going below the floor, that is than directed sharply upward with the help of beam wing, I don't see how can there be a solution to this problem within these regulations. Unless we just block the diffuser outlet :lol:
BTW Fernando felt nostalgic and decided to give Ferrari a spin? :wink:
Saykas
Saykas
26
clownfish
clownfish
Saykas wrote:
09 May 2024, 12:20
https://i.imgur.com/wfRORCv.jpeg
Looks like more water being is pushed outwards, less upwards.
clownfish wrote:
09 May 2024, 12:38
A bit like that, but only on front. Front tyres leave no vertical spray, but in the rear there is a big rooster tail spray just like it always is. It's not about tyre cover, it's about downforce, diffuser and rear wing combined with their strong vortex interaction pick up a lot of water from the rear and just send it up.
In 2026 this will be a smaller problem with narrower tyres and far less downforce than today, it's no use fixing a problem that's about to diminish on its own...
FW17
171
LMP car with all closed wheels could not prevent spray. They need some devices in side that would make them to droplets rather than mist
Xyz22
Xyz22
124
mzso
mzso
65
Vanja #66 wrote:
09 May 2024, 12:42
clownfish wrote:
09 May 2024, 12:38
Maybe the FIA shoud just prevent vortex generation, since it causes yet another problem.
Zynerji
111
Why not just put tyre scrapers on the bottom rear-third of the brake duct? Also, I've suggested a re-lamination extension behind the diffuser (just a carbon box with 5mm hex pattern mesh that is 250mm deep, and got lots of downvotes) in the past to help with the disturbed air behind a car, and I feel that would also stop the high-lift spray...
Holm86
249
FW17 wrote:
09 May 2024, 14:15
https://toyotagazooracing.com/pages/con ... 13/ogp.jpg
But LMP cars doesn't stop racing every time I rains a bit.
Personally I'd rather see F1 implement;
1. A better full wet tire
2. An FIA controlled ECU overwrite rain MAP which brings down the fuel flow to about 50%, should bring down speeds and make racing more safe
The floor edge vortex is broken up completely on F1-75 due to a massive change in front tyre fairing. Even if test wasn't a failure in terms of results, this kind of aero interference would make teams outlaw these massive fairings.
mzso
mzso
65
Holm86 wrote:
09 May 2024, 18:23
FW17 wrote:
09 May 2024, 14:15
Or they could just simply race as it is, like they did for 60 years.
mzso
mzso
65
Vanja #66 wrote:
09 May 2024, 18:36
https://www.youtube.com/watch?v=FvTtBpthJdw
Why don't the front fairings have sidewalls?
