Ferrari SF23
gordonthegun
254
Re: Ferrari SF23
After front, now rear wing:
gordonthegun
254
Re: Ferrari SF23
AMuS:
jambuka
jambuka
25
Re: Ferrari SF23
Ferrari for Qatar:
f1316
f1316
79
Re: Ferrari SF23
When did Ferrari introduce the (now commonplace) rear wing corner cutout (for want of a better term)?
Re: Ferrari SF23
f1316 wrote:
06 Oct 2023, 03:11
That cutout was present on basically all launch cars in 2022. Some teams later filled it out and even later cut it out again, Mercedes and Alpine pop to my mind. The novel thing is a discontinuous joint between flap "endplate" and the actual endplate, which Ferrari used only on the Spa wing this year, for now.
Z-one
Z-one
Re: Ferrari SF23
Vanja #66 wrote:
06 Oct 2023, 08:12
f1316 wrote:
06 Oct 2023, 03:11
https://cdn-2.motorsport.com/images/mgl ... ail-1.webp
I think what he said may be the ridge of rear wing endplate,like aston apline
The mankind’s courage and resolution will be witnessed and remembered by stars.
gordonthegun
254
Re: Ferrari SF23
Interesting views of FW:
Re: Ferrari SF23
gordonthegun wrote:
07 Oct 2023, 14:06
https://cdn-8.motorsport.com/images/mgl ... ail-1.webp
Really nice angle. I'm still not buying into their explanation that they need to setup the car with extra understeer for it to be more stable, at least not as the only explanation of the chronic understeer. Those flaps (3rd and 4th) are heavily cambered to pull off such an abrupt increase in angle that we see here and the transition to outboard section shows just how much this sacrifices the planform surface and, consequently, the available downforce.
I think it's most likely their downstream flow is very sensitive to any major changes to inboard section flap angle and an increase in resulting chord length of the whole wing. It was strange to see no incidence angle on their front suspension arms and still is, no idea what's going on there but it may have something to do with said sensitivity.
In the first part of the season, I thought they rely on extra strong outwash on the front wing for downstream performance (floor and sidepod interaction obviously) so they need such an aggressive wing angle and so they are forced to sacrifice planform surface. However, after the major changes of endplates and that whole area in Austria, which have big consequences on outwash structures, it's fairly certain this isn't the only reason to keep such a wing design. Maybe it's not even any of the reasons at all.
FDD
FDD
70
Re: Ferrari SF23
Vanja #66 wrote:
11 Oct 2023, 14:09
gordonthegun wrote:
07 Oct 2023, 14:06
Thank you for your analysis.
Also I do not expect from them to be honest with "their explanation that they need to setup the car with extra understeer for it to be more stable".
They are hiding which is normal and above all it is clever.
gordonthegun
254
Re: Ferrari SF23
gordonthegun
254
Re: Ferrari SF23
"Rear wing comparison. Medium-high load solutions for this event despite the long straight of the COTA."
Re: Ferrari SF23
Looks like the same configuration as Japan. Some people are saying that the endplate corner has been modified and I did at first until I saw a comparable angle
Japan
COTA
Z-one
Z-one
Re: Ferrari SF23
19 Oct 2023, 20:37
Japan
https://i.imgur.com/OFBuDDM.jpeg
COTA
https://i.imgur.com/WWEGXy2.jpeg
the major difference is the BW
gordonthegun
254
Re: Ferrari SF23
RWs:
gordonthegun
254
Re: Ferrari SF23
FWs:
