ISLAMATRON wrote:Those cars still didnt corner with the same cornering G's as today's, the tires did not allow for it.
There are plenty of series that employ tunnels and are within the realms of common sense. IRL & GP2 to name a couple. Ground effects are not a safety hazard if employed with proper restrictions.
But such things are pretty impossible with f1 teams going on the limts and over it(breaking the rules sounds dull :p) and the FIA setting up unclear rules.
But if they CAN manage to do it, it is a good idea, all racing series that use tunnels have good passing, so with current rear wing and front wing possitions it isnt a bad idea.
@BreezyRacer; bullshit, the DDD has 0 effect, the air is as clean as it is in the normal tunnel, it only goes throug a channel where it generates more downforce.
Also the downforce the underbody generates is good for overtaking, as its wake is less then from wings etc. so you should get more downforce from the underbody, The 2007 Panoz Champcar utilizes it and it was a good car for overtsking i believe.
