The last tracks will suit Checo driving style more. At worse he will finish P5 on these track, if he made no mistakes
The floor itself is not illegal on either car. It's the plank wear that was deemed excessive. If one chooses to call the plank the "floor" then it's a semantics thing...ValeVida46 wrote: ↑23 Oct 2023, 08:10Would Ferrari's floor have also been illegal at the previous venues it raced at?
“randomly” checked 4 out of the 20 cars! There’s your answer
Unfortunately we won't know until Vegas I think. Even the W13 could be run to the ground at Mexico due to the thinner air meaning less df so hopping wasn't triggered
That's a total stab in the dark.AR3-GP wrote: ↑23 Oct 2023, 08:15However, when a car exhibits excessive plank wear, then it implies the car was benefitting from a setup configuration which would not pass tech at the end of the GP. Maybe Merc needed to raise the car or run stiffer suspension to reduce the bottoming. We don't know what the performance of such a car would have been but it likely would have been slower.
Why would it be? The obvious point here is that Merc's pace relative to RB and McL may have been a consequence of running the car illegally low to the ground, gaining performance from that instead of the upgrade.ValeVida46 wrote: ↑23 Oct 2023, 08:10Would Ferrari's floor have also been illegal at the previous venues it raced at?
Run a legal car and you will pass "random" checks. All his biggest competitors were checked, so no point crying about it.
How is it obvious? Ferrari's relative pace was slower for exactly the same thing.Cs98 wrote: ↑23 Oct 2023, 10:28Why would it be? The obvious point here is that Merc's pace relative to RB and McL may have been a consequence of running the car illegally low to the ground, gaining performance from that instead of the upgrade.ValeVida46 wrote: ↑23 Oct 2023, 08:10Would Ferrari's floor have also been illegal at the previous venues it raced at?
Always bias in the Merc thread, We are normally hearing how the FIA and stewards let LH get away with every thing....ValeVida46 wrote: ↑23 Oct 2023, 10:39How is it obvious? Ferrari's relative pace was slower for exactly the same thing.Cs98 wrote: ↑23 Oct 2023, 10:28Why would it be? The obvious point here is that Merc's pace relative to RB and McL may have been a consequence of running the car illegally low to the ground, gaining performance from that instead of the upgrade.ValeVida46 wrote: ↑23 Oct 2023, 08:10
Unless of course there is a cognitive bias in isolating Mercedes.
Ground effect cars run lower to the ground generate more downforce, that much is obvious after two years with these regs. Ferrari's raw pace was as fast as anybody, and their race pace was faster than usual finishing only 15 seconds behind Max. We can not draw any positive conclusions about the real relative pace of competitors running illegal cars. The fact that Merc introduced an upgrade and ran the car illegally obfuscates what is what performance wise, hence why I said it puts the new floor into question. Soon enough we will know what is what.ValeVida46 wrote: ↑23 Oct 2023, 10:39How is it obvious? Ferrari's relative pace was slower for exactly the same thing.Cs98 wrote: ↑23 Oct 2023, 10:28Why would it be? The obvious point here is that Merc's pace relative to RB and McL may have been a consequence of running the car illegally low to the ground, gaining performance from that instead of the upgrade.ValeVida46 wrote: ↑23 Oct 2023, 08:10
Yes, teams are obsessing over milometers of ride height and run their cars so much on the limit because there's absolutely no performance to be gained from it. Makes sense.ValeVida46 wrote: ↑23 Oct 2023, 10:39How is it obvious? Ferrari's relative pace was slower for exactly the same thing.Cs98 wrote: ↑23 Oct 2023, 10:28Why would it be? The obvious point here is that Merc's pace relative to RB and McL may have been a consequence of running the car illegally low to the ground, gaining performance from that instead of the upgrade.ValeVida46 wrote: ↑23 Oct 2023, 08:10
Yes, I think the point that only 4 cars were checked is just wrong. They checked all top cars.
