RB20 speculation
Re: RB20 speculation
Nose definitely extends to the front, all 4 FW flaps attached to it now. No idea why they forgo a bit of front downforce for further drag reduction...
KimiRai
KimiRai
257
does the nose connect to the main plane now?
KimiRai wrote:
13 Feb 2024, 12:28
https://i.imgur.com/KtAOg0I.png
Looks like it
KimiRai
KimiRai
257
Thats interesting, considering AMR have just went in the opposite direction after a similar nose in 2023
MrGapes
33
13 Feb 2024, 12:26
From another angle:
https://pbs.twimg.com/media/GGNaUWVW8AA ... name=large
Rb19
Xyz22
Xyz22
123
KimiRai wrote:
13 Feb 2024, 12:29
Ferrari did the same (as AMR) from 2022 to 2023 correct?
KimiRai
KimiRai
257
Xyz22 wrote:
13 Feb 2024, 12:36
KimiRai wrote:
13 Feb 2024, 12:29
Ferrari did the same from 2022 to 2023 correct?
Yeah, funnily enough AMR has changed every year between the two :lol: 2022 second element, 2023 main plane, 2024 second element
maybe it doesn't really matter that much if teams keep switching all the time
Cs98
Cs98
33
13 Feb 2024, 12:26
From another angle:
Again, that's DR in an RB19. Keep it to RB20
Inlets are extreme, much like the amr24
BlueCheetah66
BlueCheetah66
33
That inlet is literally touching the top of the chassis
BlueCheetah66 wrote:
13 Feb 2024, 12:50
Edited slightly to make things clearer. Yes the inlet lower lip is very close to the top of the chassis. Significantly higher than the rb19
Cs98
Cs98
33
13 Feb 2024, 12:46
https://i.imgur.com/drTTrPy.jpeg
These pics are obviously grainy, but looks to me like the lip is so high that you'd barely see the letterbox from head on. Looks more extreme than RB19 and AMR24.
BlueCheetah66
BlueCheetah66
33
Also looks like they've gone to a squarer roll hoop inlet after going to a full circle for the RB19
13 Feb 2024, 12:58
Yup it looks squarer from all angles
