Both those would be visible on this pic, no? Unless you go with B and make it much thinner.AR3-GP wrote: ↑13 Feb 2024, 22:42Since we are speculating:
A:
https://i.postimg.cc/htZZTKdD/image.png
B:
https://i.postimg.cc/GpYPtRPS/image.png
C:AR3-GP wrote: ↑13 Feb 2024, 22:42Since we are speculating:
A:
B:
True. This angle rules those out. It is the tiniest of inlets.Cs98 wrote: ↑13 Feb 2024, 22:45Both those would be visible on this pic, no? Unless you go with B and make it much thinner.AR3-GP wrote: ↑13 Feb 2024, 22:42Since we are speculating:
A:
B:
https://i.imgur.com/qw2jD9Z.png
Wouldn't it just be the cherry on top for Merc to have moved the SIS down to a normal position and then the RB20 comes in looking like W14, winning.continuum16 wrote: ↑13 Feb 2024, 22:46We desperately need at least one HD pic because from what I'm seeing the bodywork is looking surprisingly similar to the W14. Nose connected to the front wing mainplane? Overbite? Sculpted cannon? Small waterslides? I would find it so unbelievably funny if all features were there on the RB and NOT on the W15, just from an ironic point of view. The floor and suspension will probably be quite different between the two regardless.
X-ray on Checo? Damn.Blackout wrote: ↑13 Feb 2024, 22:47C:AR3-GP wrote: ↑13 Feb 2024, 22:42Since we are speculating:
A:
B:
https://i.imgur.com/XN0DthO.png
Can someone tell me that I am crazy and seeing things...AR3-GP wrote: ↑13 Feb 2024, 22:08Last year it was noted that RB appeared to shrink the roll hoop inlet. This year it seems to have grown again?
https://i.postimg.cc/Y2Y8X1Jm/image.png
Think what you're thinking is "spray" is just reflection from the shiny surface treated carbonPinkFloydPulse wrote: ↑13 Feb 2024, 22:49Can someone tell me that I am crazy and seeing things...AR3-GP wrote: ↑13 Feb 2024, 22:08Last year it was noted that RB appeared to shrink the roll hoop inlet. This year it seems to have grown again?
https://i.imgur.com/xZJenDT.png
I highlighted with red on the nose...
You can see the spray on the right side of the wing THROUGH the nose... Almost like it has a double nose? First black part, then the yellow on top of it... Like we had those hideous penis noses from years ago...
