Thank you both
Contacted F1 support... we'll see if it get fixed before start of the season
Setup changes most likely.F1Krof wrote:What's going on with Mercedes why aren't they running?
oh reallyCaribouBread wrote: ↑21 Feb 2024, 10:34You missed the "for now" in the post?Bill wrote: ↑21 Feb 2024, 10:33too early to be cockyCaribouBread wrote: ↑21 Feb 2024, 09:51Red Bull and Alpine with some tremendous understeer for now. Perhaps its the vanity panel coverup thing for Red Bull
Car is not setup right, it’s jumping a bit in entry to T7 and takes out front right tire which locks up slightly due to bouncing.CaribouBread wrote:Second time Leclerc has a lockup?
Where are you getting onboards from?dialtone wrote: ↑21 Feb 2024, 11:06Car is not setup right, it’s jumping a bit in entry to T7 and takes out front right tire which locks up slightly due to bouncing.CaribouBread wrote:Second time Leclerc has a lockup?
Car didn’t look too bad that last run, needs a softer front though or a bit more front wing.
F1tv had some onboard, then just looking at the lines it was taking, especially out of t1.AR3-GP wrote:Where are you getting onboards from?dialtone wrote: ↑21 Feb 2024, 11:06Car is not setup right, it’s jumping a bit in entry to T7 and takes out front right tire which locks up slightly due to bouncing.CaribouBread wrote:Second time Leclerc has a lockup?
