2024 Pre-Season Testing - Bahrain International Circuit, Feb 21 - 23
Re: 2024 Pre-Season Testing - Bahrain International Circuit, Feb 21 - 23
Sainz putting the hammer down
Sainz got 1s faster than Leclerc over the winter :mrgreen:
Xyz22
Xyz22
123
21 Feb 2024, 15:27
Track is improving a lot, let's also see if Sainz will do a mini run like Max did after the push lap
Xyz22 wrote:
21 Feb 2024, 15:29
21 Feb 2024, 15:27
Yeah Max just did a 1.33.4 on a hard tyre. Track is getting quicker
CouncilorIrissa
CouncilorIrissa
Sainz did 32.5-cooldown-32.8.
Sniff your h(c)opium while you can.
UPD: and a 33.3
Xyz22
Xyz22
123
CouncilorIrissa wrote:
21 Feb 2024, 15:36
UPD: and a 33.3
So 3 push laps.
Norris flying now. Some hope for the season?
mendis
mendis
19
21 Feb 2024, 15:47
If he can do a stint on C1 like Max is doing, clocking mid to low 1.35.xxx. :)
outlap
1: 33.450
2: 26.951
1: 33.871
1: 50.679 inlap
2: 35.725 outlap
1: 36.137
1: 35.696
1: 35.612
1: 35.685
1: 35.614
1: 35.366
1: 35.169
inlap
Track Temp - 37C. Air Temp - 24C.
Cs98
Cs98
33
21 Feb 2024, 15:47
What is hopeful is comparing some of these times to RB19 a year ago. Ferrari and McL are going well faster than RB19 did on day 1 in 23.
CouncilorIrissa
CouncilorIrissa
Xyz22 wrote:
21 Feb 2024, 15:44
21 Feb 2024, 15:36
UPD: and a 33.3
So 3 push laps.
And then some.
Xyz22
Xyz22
123
mendis wrote:
21 Feb 2024, 15:48
21 Feb 2024, 15:47
outlap
1: 33.450
2: 26.951
1: 33.871
1: 50.679 inlap
2: 35.725 outlap
1: 36.137
1: 35.696
1: 35.612
1: 35.685
1: 35.614
1: 35.366
1: 35.169
inlap
No one outside Tsunoda and Piastri did similar runs to Max in terms of length (i.e. 1-2 push laps + 5-6 mini run with no DRS)
21 Feb 2024, 15:52
Xyz22 wrote:
21 Feb 2024, 15:44
21 Feb 2024, 15:36
UPD: and a 33.3
So 3 push laps.
And then some.
that's 3 push laps.. slow laps over 2mins long are not really relevant
Cs98
Cs98
33
mendis wrote:
21 Feb 2024, 15:48
21 Feb 2024, 15:47
outlap
1: 33.450
2: 26.951
1: 33.871
1: 50.679 inlap
2: 35.725 outlap
1: 36.137
1: 35.696
1: 35.612
1: 35.685
1: 35.614
1: 35.366
1: 35.169
inlap
No wonder the deg is so good, temperatures are like Antarctica.
Paa
LM10 wrote:
21 Feb 2024, 13:53
Posting various stints every 5 minutes when it’s clear that teams do completely different things (simply testing) does not make sense. If any, stints can only be compared when they’re a part of a race sim done in similar track conditions.
I find those interesting. It is not to compare to other teams, but still you can see the consistency from those or tyre degradation.
CouncilorIrissa
CouncilorIrissa
21 Feb 2024, 15:53
21 Feb 2024, 15:52
Xyz22 wrote:
21 Feb 2024, 15:44
So 3 push laps.
And then some.
6 push laps. It's the continuation of the stint. (technically not, but he used the same compound)
the first three:
