Aston Martin AMR24
abhi1200
abhi1200
35
Re: Aston Martin AMR24
Farnborough
Farnborough
101
Very interesting flow pattern there in regard to air entry of sidepod.
You can see the entrance is almost in "shadow" of the flow primary direction and looking like it's significantly masked from that aspect.
You can virtually determine the reason they've flipped the entrances on RB to fully capture that prevailing flow volume climbing up the side of the monocoque to more efficient effect.
wiktor977
wiktor977
25
Vanja #66 wrote:
22 Feb 2024, 08:54
High Res flow vis photos. The inlet seems very sensitive but it works, there's a couple of paint streak going down into the ducting right above the bottom lip curve
https://www.racefans.net/wp-content/upl ... _HiRes.jpg
What do you mean by that?
Bisonas
Farnborough wrote:
22 Feb 2024, 10:43
I guess the question is, you want to capture that upward airflow in order to send a big portion of it into the inlet, or guide it towards the undercut. Or maybe they saw in the wind tunnel that the actual airflow volume that goes towards the undercut is very similar, or even better from what they had last year while finding even more benefits elsewhere using this years concept.
abhi1200
abhi1200
35
its only testing but atleast a rough idea.
F1 TESTING DAY 1 - GEAR RATIOS COMPARISON
Aston Martin is shorter up to 7th than Red Bull 8th similar for both cars More traction for Aston, more straight line speed for Red Bull
Farnborough
Farnborough
101
Bisonas wrote:
22 Feb 2024, 11:13
Farnborough wrote:
22 Feb 2024, 10:43
The whole purpose of a intake is to get as much flow through it as possible, else by default it has to be made larger to meet the target volume etc of cooling requirements internally.
Masking it isn't productive, just waste in that design, but a very clear illustration of whats happening there from flow vis marking.
Perhaps they'll, even as we debate this, be considering the RB solution within their cfd facility to evaluate what could be an easy development direction.
wiktor977 wrote:
22 Feb 2024, 11:02
The cockpit (opening) is a sudden depression on the car and as such the front part of it pulls the air in a bit. Coupled with mandatory curvature of the chassis, you have two "sources" of local low pressure zone while the inlet is higher pressure area. This forces the air away from inlet which is not really what you want all the time, so it needs to be controlled. So that whole area is, by design, sensitive to external disturbances, but cooling and heating are not instant processes so there is no trouble if there is some brief detachment in some conditions.
wiktor977
wiktor977
25
RedNEO
30
Ironically it would kind of easy for them to switch to Red Bulls solution since it’s just an upside down version of Aston’s solution.
Venturiation
Venturiation
98
RedNEO wrote:
22 Feb 2024, 19:13
and they more wind tunnel so they can try an improved version
FNTC
FNTC
RedNEO
30
Venturiation wrote:
22 Feb 2024, 19:49
RedNEO wrote:
22 Feb 2024, 19:13
Good point. I can’t wait until they can use their own wind tunnel to maximise that extra time.
Vanja #66 wrote:
22 Feb 2024, 08:54
That inlet flow is a bit scary to be honest. Probably closer to stall than what we saw from the RB. It's an aggressive direction change considering the incoming flow angle. The rest of the sidepod viz looks great though.
A lion must kill its prey.
FNTC
FNTC
22 Feb 2024, 23:19
Vanja #66 wrote:
22 Feb 2024, 08:54
That inlet flow is a bit scary to be honest. Probably closer to stall than what we saw from the RB. Aggressive direction change.
There seems to be quite a bit of area in the inner corner towards the chassis, behind the underbite wing that doesn't get much air there, judging by the black carbon with no flow-viz on it, but most of it seem to drop into the inlet further back there.
FNTC wrote:
22 Feb 2024, 23:22
22 Feb 2024, 23:19
Vanja #66 wrote:
22 Feb 2024, 08:54
The flow-viz has mass (and thus a little bit of momentum) so sometimes it won't turn so much compared to the actual flow. However, you can just make out two streaks of the flow-viz that follow near the fillet on the chassis so it appears to be relatively attached flow. It is definitely a more delicate one however.
