That is the wrong strategy. To minimize fuel use and max efficiency you need to limit downforce and allow aero research to concentrate on minimizing drag. If they always change the geometric restrictions there will be a new orgy of downforce research every time you make a change.flynfrog wrote:actualy tweaking the aero is the pinical of optimizing for effecieny. They run as much DF as they can with the least amount of drag per engine output.
flynfrog wrote:To me reving the engine a few hundered RPM is a much better solution then any kers system. The KERS systems are overly complex and expensive not to mention much worse for the enviroment then a few kilo of fuel. This applies to road and F1 so how is that for your road relavance.
That will never work as they will just do what they do now: get the most downforce they can for the least drag. They will just push up against the edge of the limit.WhiteBlue wrote:That is the wrong strategy. To minimize fuel use and max efficiency you need to limit downforce and allow aero research to concentrate on minimizing drag. If they always change the geometric restrictions there will be a new orgy of downforce research every time you make a change.flynfrog wrote:actualy tweaking the aero is the pinical of optimizing for effecieny. They run as much DF as they can with the least amount of drag per engine output.
A flywheel system like the Williams unit will be environmentally friendly. If the batteries are too expensive F1 would avoid them given a budget restriction.
the flywheel is going to be more inefficient than batteries if its not already you are going from mechanical to electrical to mechanical back to electrical. Not to mention its got to be a service nightmare with super high speed bearings. Its also going to weigh more to add all of the crash proofing armor. Not to mention they have yet to put it in a car and probably never will.WhiteBlue wrote:That is the wrong strategy. To minimize fuel use and max efficiency you need to limit downforce and allow aero research to concentrate on minimizing drag. If they always change the geometric restrictions there will be a new orgy of downforce research every time you make a change.flynfrog wrote:actualy tweaking the aero is the pinical of optimizing for effecieny. They run as much DF as they can with the least amount of drag per engine output.
I'm not sure that's all true.... batteries aren't that efficient at storing energy, and they're also not very efficient at discharging the energy they do store, they're limited by charging rate, and they have a finite number of charge/discharge cycles before they need to be thrown away. The flywheel only needs the bearings and vacuum seals replaced....flynfrog wrote: the flywheel is going to be more inefficient than batteries if its not already you are going from mechanical to electrical to mechanical back to electrical. Not to mention its got to be a service nightmare with super high speed bearings. Its also going to weigh more to add all of the crash proofing armor. Not to mention they have yet to put it in a car and probably never will.
But isn't that what F1 should be about? Engineering challenges and innovation. The way the rules are going seems to exactly the reverse. Kit engines from Cosworth next? Good Lord. No - Holy ---.xpensive wrote:Admitting to be intrigued by the prospect of an electrical flywheel in F1, the storing ability is rather interesting.
Stored energy is mass-inertia times angular speed squared over two.
If we imagine a solid, 200 mm and 5 kg, disc, spinning at 100 000 Rpm, it will hold some 1400 kJ.
More than enough for today's storage numbers, and possibly much more with a larger disc?
But solving the mechanical challenges, bearings, stresses and vacuum, at those speeds? Good Lord.
There's been some good articles in Racecar Engineering about the Flybrid flywheel solution and all these aspects have been design and tested and show good results. One of the solutions was simply to mount the bearings outtside the vacuum casing, therefore they only need to cope with the speeds, not the vacuum. Good lateral thinking.xpensive wrote: But solving the mechanical challenges, bearings, stresses and vacuum, at those speeds? Good Lord.
any seal that spins that fast is going to be interesting.xpensive wrote:Vacuum-sealing a spinning shaft is in itself not the problem flynfrog, it's never more than an atmosphere of pressure differential anyway, Busak+Shamban has technology to do that tight enough.
But not at that surface-speed, you can handle perhaps 20 m/s reliably, but not 100 m/s as it will be if you are talking 100 000 Rpm and a 20 mm shaft.
But still interesting, nevertheless.
I like the vac pump Idea.Giblet wrote:Flybrid info form this months Race Tech magazine. The flywheel wheel is more of a drum. A larger version doesn't have to spin faster, it has to be wider, having a wider drum.
- 60,000rpm
- Flywheel is made form Carbon Fibre
- The seal doesn't have to be perfect, as a small electric motor evacuates the chamber when needed.
- Containment system in place to keep everything contained in the event of a failure.
- Entire system weighs 20kg.
- 80% efficiency over a complete cycle of charge, storage, and discharge.
- low cooling requirements
- no flammable parts
- can run many races without attention, where Mclaren throws away their batteries after every race
