chrisc90 wrote: ↑10 Mar 2024, 17:02
They were using a loophole (and possibly other teams too)
Not entirely sure how they it worked aside from the plank moving when it was close to the ground.
Surely teams can look at what height the floor needs to be to produce reliable downforce and work from there?
It does beg the question though, did RB’s previous massive rake help them in knowing how to generate downforce at a floor height that might be higher than others? Seems some teams need to deck the car in order to be fast (COTA 2023 with Mercedes) whereas RB can run high and still be fast/downforce.
I see this in the same "light" as I feel you've put it here.
There's simply huge back catalogue within RB of running unconventional floor angle, rear suspension travel etc etc. Absolutely no "catering budget" can even begin to cover this level of experience/ expertise/ exploration in that knowledge bank created and living within RB.
Wolf even took the "pizz" about the RB "running around like it's doing a handshtand" in those days.
Yes to the pedantic, I know it was a flat floor era, yes I know about the floors now, critical experience though is hugely valuable even if it works or not, it still forms a significant experience of characteristic behaviour of what happened.
Often a failure is just as valuable as acknowledged success, thats IF its learned from. It demonstrates a more full understanding of the task demanded, allows competent development analysis, can point a way forward in new rules, to keep repeating the mistake is how some teams remain static. Thats MB "bouncing" McL slow speed understeer and others like that
