willmesquita wrote: ↑05 May 2024, 13:55
LionsHeart wrote: ↑05 May 2024, 13:20
mwillems wrote: ↑05 May 2024, 10:00
We actually look decent here. It's possible we could get a podium.
But I think Sprint Qualifying gave off some unrealistic expectations.
Nothing like this. The point is completely different, Lando completed a lap on the Medium in 1:27.597. A day later, Soft set the tires to 1:27.594. Either the track doesn't evolve, or Lando is right that they made a mistake with the settings.
The increase in speed between Friday and Saturday is very small. Moreover, it is even smaller between Q1 and Q3.
To me is an obvious setup issue (ou option), track evolved a little (other teams improved).
To be honest, I'm sure the opposite is true. On the contrary, the track became slower. The fact that the others added only speaks of a more successful selection of settings, including Max. He himself confirmed that the changes were beneficial. Lando, on the contrary, was not too pleased with the behavior of the chassis. I don't see anything wrong with this. It's all part of learning. This is the first weekend where specification B was actually delivered.
I'm just used to seeing the following picture. On Friday there is a qualifying simulation, then the next day in Q1 they usually go 5-6 tens faster, and in Q3 they add another second relative to Q1. Everything is different here. I admit that I was wrong on Friday because I did not know that the asphalt was heated to 50 degrees. From other sources I found information up to 55 degrees Celsius. That's a lot.
Taking these factors into account, it is not surprising that the tires are having a hard time here in one fast lap. The race should be easier, since one pitstop is the most advantageous option here.
I just forgot that the weather in Vice City is usually hot.
To be precise, the city is located at a tropical latitude.
Below is a visual demonstration. Time difference between 2023 and 2024 in Miami. Most of the teams went slower, although in the previous quali weekends it was usually the other way around. The track became slower. McLaren stands out a lot just because they themselves were slow last year.
