AMUS…all the upgrades they brought are to increase the load which helps reduce the tyre wear. I guess there is a specific problem which causes the tyre wear but the upgrades are still there to reduce the tyre wear they just want a headline
The section of the floor below Aramco sign looks raised now? Or is it a light trick?KimiRai wrote: ↑17 May 2024, 13:04Two rings were added it seems? Not sure if anything else changed above, certainly below
https://i.imgur.com/PAbFiyO.jpeg
Miami
https://i.imgur.com/aAVH5Dk.jpeg
I see what you mean. That means it's only holding on by the 2 rings. That there is a gap behind that for air coming from the front to pass through there.KimiRai wrote: ↑17 May 2024, 13:04Two rings were added it seems? Not sure if anything else changed above, certainly below the floor
Miami
