Flexiwings 2024
mwillems
45
Re: Flexiwings 2024
Just_a_fan wrote:
18 Jun 2024, 20:13
mwillems wrote:
18 Jun 2024, 14:50
LM10 wrote:
18 Jun 2024, 14:19
What’s that even supposed to mean? :lol:
Which secret?
Might they be considering that the floor could be stalled with a certain amount of flex ?
It's a way of controlling the aero balance - at low/medium speeds the front wing gives good downforce helping the nose turn in. At high speed, the front wing bleeds off some downforce giving a slight bit of understeer which is a desirable thing in a high speed corner.
Yeah but I'm wondering if the wing prevents enough airflow going to the floor it could stall it and reduce drag further.
I get how it reduces drag and ftont DF at higher speeds and returns DF at lower speeds.
I'm just not sure yet how much of the wings flex or drop as the video is limited. Is it just the elements?
-Bandit
PapayaFan481
PapayaFan481
Re: Flexiwings 2024
SirBastianVettel wrote:
18 Jun 2024, 10:10
Is it really that difficult to come up with a system for the FIA to measure this correctly so this issue can be solved once and for all.
I guess the only fail safe method would be if they attached sensors to the front wings.
If I come across as blunt, I apologise, it's my ASD. Sometimes, like an F1 car aqua-planing, it gets out of my control.
KimiRai
KimiRai
299
Re: Flexiwings 2024
PapayaFan481 wrote:
18 Jun 2024, 22:56
18 Jun 2024, 10:10
More sensors! For example sensors could not detect some false starts and afaik FIA no longer solely depend on them. Good old eye method others make fun of :D
Re: Flexiwings 2024
mwillems wrote:
18 Jun 2024, 20:44
Just_a_fan wrote:
18 Jun 2024, 20:13
mwillems wrote:
18 Jun 2024, 14:50
One would expect more air being able to reach the floor if the FW trailing edge is lower.
Re: Flexiwings 2024
PapayaFan481 wrote:
18 Jun 2024, 22:56
18 Jun 2024, 10:10
You could give the teams FIA-supplied front wings. Never going to happen, but it's also a method of preventing excess flex.
Rodak
Rodak
37
Re: Flexiwings 2024
Remember, F1 wind tunnel speeds are limited by regulation to 50m/sec (180 kph. 112 mph) so kudos to the teams if they are able to extrapolate from 112 mph to 210 mph and calculate for wing deflection and develop materials/structures that act as they desire at full speed.
SiLo
139
Re: Flexiwings 2024
Rodak wrote:
19 Jun 2024, 06:07
Sometimes I wonder how much more interesting the sport would be if they had full size wind tunnels and could test at whatever speeds they wanted.
Felipe Baby!
mwillems
45
Re: Flexiwings 2024
Just_a_fan wrote:
19 Jun 2024, 00:45
mwillems wrote:
18 Jun 2024, 20:44
Just_a_fan wrote:
18 Jun 2024, 20:13
But is that is all that is lower? Have they got the suspension set up to drop the front sufficiently that the elements are working in tandem with other areas?
Not suggesting that is happening, it is just that there is very limited footage of what the front of the cars are doing at high speeds. Would love to see a frontal pic of the Mclaren at 300kph+ from Canada.
-Bandit
Re: Flexiwings 2024
mwillems wrote:
19 Jun 2024, 11:22
Just_a_fan wrote:
19 Jun 2024, 00:45
mwillems wrote:
18 Jun 2024, 20:44
Occam's Razor applies.
dialtone
dialtone
123
Re: Flexiwings 2024
The likelihood a flexi wing gives you 1% more performance is very slim at best.
mwillems
45
Re: Flexiwings 2024
Just_a_fan wrote:
19 Jun 2024, 12:30
mwillems wrote:
19 Jun 2024, 11:22
Just_a_fan wrote:
19 Jun 2024, 00:45
I think I'd prefer to see more than just a tiny view of a little part of the wing that we can see through the Halo to understand the scope of what is being done.
-Bandit
Rodak
Rodak
37
Re: Flexiwings 2024
SiLo wrote:
19 Jun 2024, 10:26
Rodak wrote:
19 Jun 2024, 06:07
Yeah, Sauber, a long time ago when they were with BMW, built a state of the art full scale high speed rolling road tunnel. Too bad they can't use that full scale.
Luscion
Luscion
113
Re: Flexiwings 2024
Reached by the oe24 news outlet Helmut Marko made these statements about the flexible wings case raised by Red Bull itself: "Mercedes has a new front wing, and in the TV images for the Canadian GP we can see that they were significantly bent. However, in the technical tests the wings showed that they have the necessary strength. This does not surprise me. I don't know how often we had to check our wings."
"There is a well-defined procedure with weights under which a wing must not bend. It's quite the practice to push everything to the limit so that the wing adapts to the technical checks. Then in the race, the wing is lowered, providing better aerodynamics," Marko added, "In Montreal everything went well, both ours and our competitors'. There will be a new technical verification in Barcelona, Austria and so on. Is it fair to say that Red Bull wants to clip Mercedes' wings? It's a funny pun, it has something satirical about it, but only the FIA can do that."
https://www.formulapassion.it/f1/f1-new ... mmagini-tv
Re: Flexiwings 2024
The interviewer asks mundane questions so receives mundane answers
chrisc90
Re: Flexiwings 2024
Extra checks?
