2026 Aerodynamic & Chassis Regulations
r85
r85
Re: 2026 Aerodynamic & Chassis Regulations
Is there a chance that we'll see aggressive rake angles return with the flat floors or is that only possible with the complex suspension from the previous regs?
FW17
169
Today is the day for signoff of the new regulations, is there any talk about it?
BlueCheetah66
BlueCheetah66
33
Vanja #66 wrote:
27 Jun 2024, 07:35
bhall II wrote:
27 Jun 2024, 01:59
I'm mainly just ranting. :D
It's been quite some time since I've followed F1 closely. I just happened upon those FIA renderings of the '26 regulations, and it irritated me a bit to see just how much of an about-face they represent after everything else basically killed my fandom.
"Ooops" lol
Unfortunately, those front wings are about the only thing that's common with cars from 20 years ago. Tight chassis regulations will lead to a field of identical-looking cars already in 2027, the only way to distinguish them will be an occasional different-looking airbox :(
Although the boxes might be kind of restrictive, I think the wording of the regulation is a bit more open than in the current cars. There's a lot less restriction of sections in Y and X plane in both the floor and the endplate/footplate parts
MIKEY_!
Any early thoughts from our aero gurus about the key challenges for this aero ruleset?
For example, how to treat the vortex coming off the top of the floor edge inwash fin/bargeboard - try to move it inwards or outwards relative to the floor edge, try to strengthen it or weaken it, try to draw it under the floor or exclude it at all costs? Lots of possibilities I'm not qualified to guess at.
I'm sure some of you have plans to post cfd when you get time, but I'm interested in any first impressions in the interim.
MIKEY_! wrote:
01 Jul 2024, 08:34
This will be one of the big questions of early 2026, different teams will have different approaches. Impossible to say anything now, all teams will run multiple solutions on January 1st 2025 :mrgreen:
In theory it should have an outward top side rotation, meaning it could potentially draw turbulence inside the diffuser as it expands and gets closer to rear tyre if it strong enough. This is the opposite rotation of the floor edge vortex that is formed by floor fences on cars today.
627
what's happened to the 'active aero' ?
mzso
mzso
64
So what are the regs? Whatever the final draft was?
Stu
mzso wrote:
01 Jul 2024, 17:23
Released on the FIA website, I think. I know that the teams have them.
In summary…
Like being forced to wear a straight-jacket in a locked suitcase.
Pure PU formula!!!
BlueCheetah66 wrote:
30 Jun 2024, 21:44
As per --> https://www.fia.com/sites/default/files ... -06-24.pdf
3.1.4 Component Bodywork
Unless otherwise stated, all individual Bodywork Components described in Articles 3.5 to 3.11, and in Article 3.14, prior to any Trim and Combination operations, must:
a. be single volumes that are simply connected.
A simply connected volume is a volume where any closed curve lying on the surface can be continuously contracted to a single point without leaving the surface.
b. in any X, Y and Z plane, only contain a single section.
This single-section issue with 3.1.4b. This is the real killer...
