Concept power units from 2030
Big Tea
Re: Concept power units from 2030
Some while back I had a Toyota that had an auxiliary shaft off the front of the engine driving "stuff".
Could it be possible to do something similar with CVT style traded off RPM|Torque to drive from any level and give the required speed at the generator?
Yes, over complicated and probably not practical in a race car unless it was way under start weight and in place of ballast
Farnborough
Farnborough
106
Currently, the MGU K is driving into the front end of crankshaft, I believe for all makes.
Which means that the crankshaft is used as "driveshaft" to gearbox route and not independent. The IC and the E both share the output to clutch effectively to make them fully coupled.
Whether that will be same for 2026 is not disclosed anywhere public, that I'm aware of.
wuzak
wuzak
470
Farnborough wrote:
07 Aug 2024, 16:10
5.20.3 All mechanical power to and from the MGU-K must pass through a single shaft to the MGU-K transmission. The connection to the ICE crankshaft must be ahead of XPU=100.
XPU=0 is the forward mounting plane of the PU/ICE.
So the connection of the MGUK to the ICE is to the front of the crankshaft.
For reference, XPU = 480 is the position of the gearbox casing mounting faces.
wuzak
wuzak
470
mzso wrote:
06 Aug 2024, 21:29
Chuckjr wrote:
03 Aug 2024, 07:12
This must be why there is concern that the ICE will be at full revs around places like Lowes hairpin in Monaco — as ICE will mostly act as a recharge facility for the batteries so that constant torque is available from the motor to drive the rear wheels. Like a diesel train, essentially? Because it’s so efficient, and efficiency will win the race with the way they are going with power units in 2026. Hope that’s correct.
Well, if they can rev the engine in neutral it's possible, I think. Otherwise I don't think such gearing exists to do full revs.
The driver would have to put it in neutral and then select 1st after.
The computer can't decide when to change gears, only reject gear changes to protect the engine.
mzso
mzso
65
saviour stivala wrote:
07 Aug 2024, 07:45
mzso wrote:
06 Aug 2024, 21:29
Chuckjr wrote:
03 Aug 2024, 07:12
Isn't an engine capable to rev at full revs in all the gears, or better put, aren't all gear designed/calculated so as the engine can reach full revs in each one?.
Sure, but there's no reason to have gearing that maxes out rpm at hairpin speeds
mzso
mzso
65
wuzak wrote:
08 Aug 2024, 11:14
mzso wrote:
06 Aug 2024, 21:29
Chuckjr wrote:
03 Aug 2024, 07:12
Wouldn't the clutch be enough?
saviour stivala
saviour stivala
52
mzso wrote:
08 Aug 2024, 11:33
07 Aug 2024, 07:45
mzso wrote:
06 Aug 2024, 21:29
Agree with that.
wuzak
wuzak
470
mzso wrote:
08 Aug 2024, 11:37
wuzak wrote:
08 Aug 2024, 11:14
mzso wrote:
06 Aug 2024, 21:29
Yes, but also has to be manually operated.
The clutch can be operated by the computer for very brief periods.
But, there is a rule about partial throttle fuel flow.
5.4.5 At partial load, the fuel energy flow must not exceed the limit curve defined below:
• EF (MJ/h) = 380 when the engine power is equal to or below -50kW
• EF (MJ/h) = 9.78 x engine power (kW) + 869 when the engine power is above -50kW
If the "engine power" is 0kW, the fuel flow would allow approximately 100kW to be generated using the ICE as a generator.
Though I'm not sure what they mean by "engine power".
Maybe demand?
648
broadly ....
the above is saying that WOT the ICE is effectively a constant torque device
so from 2026 the MGU-K can't be a constant power device
it won't get much generation if only doing 30% rpm - only about 30% of 350 kW
wuzak
wuzak
470
Tommy Cookers wrote:
08 Aug 2024, 13:58
broadly ....
The above is for partial demand.
The maximum fuel flow is = (0.27 * rpm + 165) MJ/h, maximum 3,000MJ/h (10,500rpm and above).
DenBommer
DenBommer
What do you think of this motor:
Something for after 2030?
bananapeel23
Are we realistically going to see new PUs in 2030? That would mean the 2026 ones only last 4 years. I feel like the teams will be reluctant to throw their years of R&D away after only 4 years?
Is the idea that the carryover from 2014 to 2026 will make the teams more willing to go to a completely new layout in 2030, since the 1.6L V6 will be a 16 year old layout by then?
DenBommer
DenBommer
bananapeel23 wrote:
04 Sep 2024, 13:19
I don't mean right after 2030. But maybe more around 2033/34?
mzso
mzso
65
DenBommer wrote:
04 Sep 2024, 12:46
On first glance (at the animation) the concept seems very similar to the radmax engine Zynerji mentioned.
The seals constantly scraping the barrier seems a tad problematic.
DenBommer
DenBommer
On the other hand, there’s probably also a reason why they have stuck with the piston engine all these years.
