We're all collectively falling for fanfiction sprinkled with some technical jargon because it fits some circumstantial evidence. Very disappointing.Even if this thing were real, the system Scarbs has shown literally wouldn’t work. The pressure everywhere in the rear hydraulic circuit will equalise so the valve doesn’t do anything unless it’s fully blocking off one side of the brakes (which it won’t be because you’d end up doubling the caliper pressure on the inside wheel or locking the pressure on in the outside one… not at all doing what you’d want)
These cars have variable brake pressure on the rear wheels due to variable ERS harvesting, so I'm pretty sure the "doubling of caliper pressure" could be worked around if that was the caseVaexa wrote: ↑16 Aug 2024, 15:43u/GaryGiesel (who, you know, actually works in the sport, unlike Windsor, Scarbs or the guy who wrote the RN365 article) seems convinced the system peddled by the article and Scarbs wouldn't even work.
https://www.reddit.com/r/F1Technical/co ... s/lidrnd8/
I find it far more likely he just wouldn't have said anything at all if Red Bull were actually doing anything like what the RN365 article proposed.
If you can achieve uneven braking through the ERS-system without being caught, why would you go through the trouble of trying to achieve the same thing with the traditional brake system?Holm86 wrote: ↑16 Aug 2024, 16:06These cars have variable brake pressure on the rear wheels due to variable ERS harvesting, so I'm pretty sure the "doubling of caliper pressure" could be worked around if that was the caseVaexa wrote: ↑16 Aug 2024, 15:43u/GaryGiesel (who, you know, actually works in the sport, unlike Windsor, Scarbs or the guy who wrote the RN365 article) seems convinced the system peddled by the article and Scarbs wouldn't even work.
Have you ever seen a current employee admit that a team is using a gray zone of regulation?Quantum wrote: ↑16 Aug 2024, 12:47Not sure I was clear.
Yes, he's a mechanic in the garage every weekend. We established this fact by way of the citations I provided.
Specifically, prepping the PU and checking it's fluids.
Not responsible for the brakes or any lines associated to the brake function. This would be a role for someone else. Maybe that's clearer.
Read it again, never said you could use the ERS system to achieve uneven braking left to right, i said the brake system already have valve reducing brake pressure to the rear when the ERS is harvesting, it could be used to not have double brake pressure on ONE caliper, but you would still need some sort of diverter valve left to right as scarbs is suggesting. And nobody is saying that scarbs drawing is 100% correct, it's only a suggestionCurbstone wrote: ↑16 Aug 2024, 16:47If you can achieve uneven braking through the ERS-system without being caught, why would you go through the trouble of trying to achieve the same thing with the traditional brake system?Holm86 wrote: ↑16 Aug 2024, 16:06These cars have variable brake pressure on the rear wheels due to variable ERS harvesting, so I'm pretty sure the "doubling of caliper pressure" could be worked around if that was the caseVaexa wrote: ↑16 Aug 2024, 15:43u/GaryGiesel (who, you know, actually works in the sport, unlike Windsor, Scarbs or the guy who wrote the RN365 article) seems convinced the system peddled by the article and Scarbs wouldn't even work.
I always thought highly of Scarbs, but I reckon GaryGiesel is right and Scarbs really misses some basic fluid mechanics in his design.
No. The idea of a valve is just completely wrong. This would need an adjustable pressure regulator and bleeding system which is very obvious and blatant cheating as by the rules since years. You are on the wrong track with this, sorry.
I am surprised, but most posters here on this brake topic do not even know about the brake-by-wire system or how it works.
Yep. The idea of the valve is technically nonsense and nonsense by the rules as it is clearly against the rule about the brake pad force and the "mass damper rule" that forbids any inertia driven system.
There is no valve. It is always brake master cylinder to caliper, nothing else. An F1 car has three master cylinders, one front to calipers, one rear to BBW and one in the BBW system to calipers.
With Pérez, the WCC would be a difficult main goal; he is just that bad. The WDC is a more natural main goal for them. I mean, if Max wins the championship, how much can we criticize Red Bull about their design path? Not every team is perfect, but come on, let's look at this from another perspective; the Red Bull driver is leading the championship by 78 points, and we are talking about what Red Bull should have done differently.Curbstone wrote:How do you know they have chosen to aim for WDC? At the end of last year they were convinced the could sort out the weaknesses of 2023, last years they already put a lot of effort to give the car a wider set-up window in order to have Perez be more comfortable with the car, and for this year they changed some concepts in order to bring more room for development. This doesn't sound like a team that will design a car just for Max. Also, Max has been complaining a lot about not having a strong front-end and having difficulties to rotate the car.Jurgen von Diaz wrote: ↑15 Aug 2024, 14:25Yes, you design the car for the full year. They have chosen their aim for the WDC, and if Max will be champion, how can we doubt their design path? They clearly haven't got such dominant tools like the hybrid-Mercedes that they can run their cars underpowered, so Red Bull has chosen this design path so Max can push it to the limit and towards the championship. If they had chosen a different design path, could they even fight either championship and Perez would be happier? We'll never know.Curbstone wrote:
You design the car for a full year, not just half a year. Let's have a look at the points tally and number of wins at the end of the year before we state Red Bull did a great job with it's car design.
I have some strong doubts. Looking at the steps others have made it doesn't seem they are close to the performance ceiling, so I don't believe RB should be either.
I don't believe it's a design path that suits Max. I think the car has some serious flaws which makes it hard to setup and which requires an exceptional driver to drive around the issues.
If someone is a mechanic who has worked at the team in many roles over the years, who speaks to their colleagues daily, helps to build/take apart the car every weekend. In my view it is plainly absurd, silly, ridiculous to assume they cannot know anything about the brake system and their view should therefore be discounted because their current primary role is working with the PU. I don't see how that's unhelpful, condescending etc. just my view on someone else's point being incorrect.catent wrote: ↑16 Aug 2024, 20:49On the topic of condescending, unhelpful, unconstructive posts, what do you think about calling someone else’s opinion “ridiculous”?organic wrote: ↑16 Aug 2024, 15:17Not sure if you were trying to be condescending, but it's not helpful to constructive discussion and not appreciated.Quantum wrote: ↑16 Aug 2024, 12:47
My point is that he doesn't work on the power unit in a vacuum. Your suggestion that because he works on the PU he would therefore necessarily not know anything about the braking system of the rb20 is ridiculous
<personal stuff removed>RacePaceDemon wrote: ↑17 Aug 2024, 03:32<personal stuff removed>catent wrote: ↑16 Aug 2024, 20:49On the topic of condescending, unhelpful, unconstructive posts, what do you think about calling someone else’s opinion “ridiculous”?organic wrote: ↑16 Aug 2024, 15:17
