Red Bull RB20
hollus
Re: Red Bull RB20
Speculation in the team threads, please!
If it is not in THIS car, it probably should not be in the car thread.
(Posts have been moved to the team thread)
Z-one
Z-one
回复:红牛RB20
RB20 has used flap BW in baku
pantherxxx
pantherxxx
Re: Red Bull RB20
🚨 Red Bull reportedly set to bring a radical floor to Baku, which would be a mix of the last 3 floor upgrades, according to
@Racingnews365
The team sees it as the best solution to prevent the efforts of the upgrades from being wasted, taking into account that each individual part had a positive response.
Lasssept
43
Re: Red Bull RB20
Emag
Emag
108
Re: Red Bull RB20
That is a weird change. They literally glued a cover at the expansion area.
To me it looks like they just took volume away from the diffuser. What are the desirable effects of such a change?
Developer of F1InsightsHub
Z-one
Z-one
Re: Red Bull RB20
like ferrari spec 22
Paa
Re: Red Bull RB20
Emag wrote:
13 Sep 2024, 10:55
As I understand they went too aggressive with recent updates. DF was there, but balance was gone making the car very difficult to drive, so they could not utilize the extra DF. (similar to what happened with Merc in 2022-2023).
It seems that they are dialing it back a bit, aiming for lower overall, but more usable downforce.
Re: Red Bull RB20
Ferrari most recent update also went back to something like that.
Lasssept
43
Re: Red Bull RB20
Re: Red Bull RB20
Emag wrote:
13 Sep 2024, 10:55
Yes, volume is reduced. The vertical kick on the keel generates some downforce which is very sensitive to ride height. These vertical kicks created some trouble for Ferrari on their Spain floor, so they removed them in Hungary and later removed the keel kick too. I suspect this is a quick fix for RB in order to give them some more room to expand setup window without inducing bouncing with those keel kicks
They've also done a hack job with the beam wing, this is smaller than Monza spec and clearly cut to a dramatic shape.
Re: Red Bull RB20
So they say this is patch-work floor that is to be monitored until Singapore. A final version will be made after that for Austin.
venkyhere
venkyhere
Re: Red Bull RB20
The changes look chop-shop fixes ; but seems to work.
Body language of the car looked good in FP1.
By taking away diffuser kicks and making the keel conventional (more like 2022) , of course they lost 'volume' and hence a smaller 'expansion ratio' from the floor, but doesn't it also mean they have to now 'buy' more downforce from their main wing ? Which in turn means a mega struggle for top speed in the 2km straight of sector3 ?
Re: Red Bull RB20
Emag wrote:
13 Sep 2024, 10:55
More stability across a range of ride heights, I would assume
13 Sep 2024, 13:48
Monaghan seemed to suggest that they could bring more changes to Singapore
Paa
Re: Red Bull RB20
13 Sep 2024, 14:44
Makes sense to test even small iterations to get the feel of the general direction they would want to move forward.
They stated that they have to ignore WT and sim figures and only rely on track data so these weekends are effectively wind tunnel runs for their iterations.
Re: Red Bull RB20
Paa wrote:
13 Sep 2024, 14:49
13 Sep 2024, 14:44
This is in the team thread but very relevant to the current changes happening on the car so I'll post it here
Monaghan indicated that the Baku modification is a first step, given the limited time, and that there will be more to come in Singapore next weekend. “The lessons are sort of continuous and the immediate reaction tends to be in subsequent races,” he said. “So it's a testament to everyone that we made it. A lot of hard work, and that hard work will continue. Singapore is only a week away . So it will potentially be another evolution for us. So if we were able to do it for this race, it's certainly not the biggest modification we've ever undertaken in terms of changing geometry. It is a small modification. Could the effect be good? YES. And I think the concrete proof will be on Sunday afternoon.”
