2024 Scuderia Ferrari F1 Team
dani5549
dani5549
Im not worried, always FP3 is bad for Ferrari...
Emag
Emag
84
Yeah, Leclerc just barely faster than FP2. Something is off, but I am sure they will claw back some time for quali. The car was behaving well yesterday and they had pace.
Also, on the mediums they were quite competitive, so it’s probably a tire-related issue. Temps might have been slightly off and you bleed laptime everywhere.
catent
Well, they have 2-1/2 hours to try to get things to the best place possible.
Fingers crossed it’s partially temp/setup related and they’ll come alive again during qualifying.
I also suspect the (now classic) pirelli lottery is potentially at play, too; it’s almost as if these tires are engineered to be a coin flip. Not sure whether it was a bad set of softs, but either way, tire temp is likely to be involved.
Fakepivot
Fakepivot
what were they doing with that checking tire pressure tho? did they slight deflate?
ScuderiaLeo
Why did they do an extra lap on mediums? The drivers didn't get to finish tweaking their setups because they ran out of time...
Autobahn303
Autobahn303
Fakepivot wrote:
21 Sep 2024, 12:39
Thinks so. Probably because of overheating.
Xyz22
Xyz22
123
I wonder if they made significant changes compared to yesterday where Leclerc was quite happy
https://x.com/leclercdata/status/1837139648579006820
CRazyLemon
CRazyLemon
Anthony Davidson suggested Sainz car was heavy when we watched his lap. I also never got to see if they were new softs, got the impression they were on a used set.
FittingMechanics
FittingMechanics
16
CRazyLemon wrote:
21 Sep 2024, 13:05
Sainz on new softs.
Leclerc on new softs.
Confirmed by checking F1TV onboards (they exited pits about 13 minutes before end of session).
Xyz22
Xyz22
123
What the hell are they doing?
Emag
Emag
84
Xyz22 wrote:
21 Sep 2024, 13:10
https://pbs.twimg.com/media/GX_uENlXMAA ... =4096x4096
To be fair that was the first time (that I remember) seeing a car alter tire pressures like that on the pits. I always assumed the pressures would be altered by a Pirelli delegate inside the garage before the tires are put on the car.
Xyz22
Xyz22
123
Emag wrote:
21 Sep 2024, 13:11
Xyz22 wrote:
21 Sep 2024, 13:10
To be fair that was the first time (that I remember) seeing a car alter tire pressures like that on the pit zone. I always assumed the pressures would be altered by a Pirelli delegate inside the garage before they are put on the car.
Exactly. Again what the hell are they doing?
FittingMechanics
FittingMechanics
16
Emag wrote:
21 Sep 2024, 13:11
Xyz22 wrote:
21 Sep 2024, 13:10
To be fair that was the first time (that I remember) seeing a car alter tire pressures like that on the pits. I always assumed the pressures would be altered by a Pirelli delegate inside the garage before they are put on the car.
This was a surprise to me as well. Pirelli mandates tire pressures, how can you control what the mechanics do?
deadhead
52
Bryan : "front wing?"
Charles : "We can, but I just have no grip. Let's do +4 to try."
Bryan : "Copy, yeah, we try something."
Charles : "Can we get into the garage just to try something very quickly?"
+4 is not as bad as +6 ?
Very weird lap comparison for Leclerc's FP2 and FP3 laps. Better top speed and overall acceleration (higher PU mode) and some corners are quicker and some are taken with the same apex speed as FP2 lap. Yet no substantial lap time improvement, 2 tenths were all on PU mode basically. Something was very wrong with tyres, braking was also poor on several occasions, quite poor grip on acceleration and braking
