2024 Scuderia Ferrari F1 Team
Emag
Emag
84
.Bole wrote:
23 Sep 2024, 10:08
I think as f1uno pointed, our new fw doesnt flex as much as mclaren’s. Its first iteration, they probably went more conservative due to rules and having less experience with that stuff
I feel like the front wing on the SF23 this time last year flexes more than the front wing they brought for the SF24 here this year. I am pretty sure they know how to make a front wing that flexes more if they want to. The limit to this new one's flex is probably a balancing / compromise thing for the best overall performance with this car.
Seanspeed
Seanspeed
bananapeel23 wrote:
23 Sep 2024, 13:00
The current F2 field must be outrageously good given how well Bearman and Colapinto have performed after being hastily thrown into a seat and told to race. Their necks aren't ready. They have very little real F1 experience and little to no time to prepare, yet were immediately on the pace.
The crazy thing is that Bearman and Colapinto aren't even the best drivers in F2 this season. Colapinto isn't even the best F2 rookie, arguably not even top 3. I think he has already made it clear he deserves an F1 seat. If an F2 rookie that isn’t even top 3 is this good, just imagine how good someone like Bortoleto must be.
Surely this is the strongest F2 field ever? Maybe you could argue for 2018, but I don't think so.
Assuming you're not joking, no, F2 is just whacky this year, with heavy inconsistency and mixups in terms of what drivers or teams are able to gel with the new car at a given weekend.
It's frustrating in that it's nearly impossible to really read anything into this F2 field as a result.
.Bole wrote:
23 Sep 2024, 10:08
With Ferrari's base setup being developed around a FW that "stays the same" around the entire lap, it makes sense not to go super aggressive with this at first, or you might end up with a different set of problems.
Typically the team would be somewhat front limited in slow corners, and well balanced in medium-high (provided the floor wasn't acting up) what they need is a wing that has a bit more on slower speeds and around the same pressure in medium-high.
CouncilorIrissa
CouncilorIrissa
Vanja #66 wrote:
23 Sep 2024, 10:03
CouncilorIrissa wrote:
23 Sep 2024, 00:41
All in all the outcome of the last two races is triggering me to no end. So annoying.
It was clear since Japan SF24 is too gentle with tyres in Q and they over-corrected this feature of SF23, but it wasn't a frustrating issue as it didn't cost them any wins realistically. Right now an easy win and a good shot at the win were lost because of tyre warm up and it would completely change the outlook of this season and obviously the WCC fight.
And people were angry that Cardille was let go so easily and Serra was recruited in his place last year :mrgreen:
They tend to overcorrect the failures of the predecessor, yeah. They went from SF70H (max downforce at all costs), to SF71H (a pretty balanced car), to SF90 (dragster). Then from F1-75 (on the draggier side) to SF23 (another dragster).
I was one of the people angry for letting him go mostly because Ferrari's track record after letting people go is suspect. And Cardile had a decent track record of cleaning up the mess he inherited from Sanchez. But it looks like it's working out for the team.
scuderiabrandon
103
23 Sep 2024, 20:04
Vanja #66 wrote:
23 Sep 2024, 10:03
23 Sep 2024, 00:41
A 'decent track record' is extremely generous. Had one good update when he took over from Sanchez. Several rather disappointing once.
CouncilorIrissa
CouncilorIrissa
scuderiabrandon wrote:
24 Sep 2024, 00:42
23 Sep 2024, 20:04
Vanja #66 wrote:
23 Sep 2024, 10:03
Which ones?
Japan spec floor for the SF23 and launch-spec SF24 were pretty decent imo. The Imola update was 50/50, they got closer to RB (although it remains to be seen whether it was self-imposed by RB or not), but got leapfrogged by McLaren (but updates of their magnitude are definitely not the norm).
The only definitively disappointing update that comes to mind was the silly Barcelona spec floor.
23 Sep 2024, 20:04
I think it's one thing to hastly boot the chief designer after one car/season hasn't gone to plan(we had a lot of that in that time inbetween the Todt dream team and the Binotto era) and the current "we don't think he's worth that much" that happened with both Sanchez and Cardile.
Plus the current cost cap era, it kinda encourages movement vs going over the top to hold on to guys like that.
scuderiabrandon
103
24 Sep 2024, 00:50
24 Sep 2024, 00:42
23 Sep 2024, 20:04
Which ones?
The launch spec SF-24 had many flaws, hidden by the fact that McLaren were slow at the start for some odd reason. Starting to think they were holding back to secure more ATR. Inherit flaws, those that only get fixed during the winter. It seemed like a good base to build from, but here we are almost in October and none of those problems have been solver. Still a big question mark over the bouncing concern.
Funny enough, around the same time his departure was announced, confirmation that there'd be a switch to pull front suspension and relocation of the cockpit. Seems like he might have vetoed against things some member wanted to implement much earlier. Could be coincidence, I don't think so though.
Truth is, it was too hit or miss with him anyway.
24 Sep 2024, 01:56
It's hard to gauge what was a too conservative choice and what was a choice made to prevent introducing new challenges and problems. Other than tyre warm up, which was clearly too conservative even if understandable to an extent, I don't think any other choice was too conservative. Gearbox case and pull rod rear were redesigned and it's working fine, chassis and lower SIS tube were redesigned and it seems ok. Front was redesigned, but kept as push rod and I don't think this was a bad choice seeing how many core issues SF23 turned out to have. Pull rod front and cockpit repositioning for next season are not minor details and if they think it will be an improvement it's gonna yield some non-downforce lap time gains which others don't have available.
After Canada fiasco, it was clear they were too conservative with tyre warm up and this is something Cardille was responsible for. If they planned to overcome this limit by improving downforce, and judging by their statements at the time - they did, but were blind sighted by downforce limits and return of bouncing, this is also something Cardille was responsible for. I knew we can't expect an epic car for history books from Cardille and I think they did an ok job with SF24, but now that they have a stable base they need to go all in for next season and they can't afford to be too conservative. Calculated risks with experienced anticipation of development and lap time limits is needed and Serra's experience should fit like a glove with that.
It's a very important detail that they've opened up a new development path with Monza floor and it's reassuring to see Red Bull copying it instantly for Baku floor experiments. Together with more front wing flexing and gains with pull rod front, cockpit position and better tyre warm up, the 25 car seems to have all the right ingredients for a strong and competitive start.
We shouldn't forget McLaren copied RB's floor concept approach and they seem to have hit a limit, using basically the same floor with minimal tweaks for 13 races straight, while their plan was to introduce a whole new floor in Silverstone, 7 races ago. There is no rumour, let alone official confirmation, that they will have a new floor in Austin. RB gave up on too many vertical kicks (like Ferrari) with Baku floor and we can be sure they will follow down this path as well with Austin upgrades.
AeroGimli.x
.Bole
.Bole
I am wondering how much would changing suspension concept set us back for next year
deadhead
.Bole wrote:
24 Sep 2024, 12:55
I’m really surprised that they are doing such a big change in the last year of the regulations, it seems like they think they got it wrong 4 years in a row now?
Xyz22
Xyz22
123
deadhead wrote:
24 Sep 2024, 14:54
.Bole wrote:
24 Sep 2024, 12:55
The current layout is not "wrong". Pull rod front suspension is just better from an aero point of view.
.Bole
.Bole
deadhead wrote:
24 Sep 2024, 14:54
.Bole wrote:
24 Sep 2024, 12:55
Exactly what i am saying why do it now, its not like this car is far off the top that we need this kind of big change.
Xyz22 wrote:
24 Sep 2024, 14:58
Yes, it will remain to be so for 2026 cars as well, one od the very few pieces of the car that will be allowed to generate outwash because it naturally does (when it generates downwash with incidence angle). If they didn't plan to keep it in 26, no reason to change it for one single season, hopefully :lol:
AeroGimli.x
Venturiation
Venturiation
98
deadhead wrote:
24 Sep 2024, 14:54
.Bole wrote:
24 Sep 2024, 12:55
To get data for 2026
