bananapeel23 wrote: ↑02 Nov 2024, 20:41
_cerber1 wrote: ↑02 Nov 2024, 20:26
bananapeel23 wrote: ↑02 Nov 2024, 20:21
Is the idea that the water evaporates inside the tyres and that the energy required for a phase change cools the carcass and then the resulting steam keeps absorbing some of the heat?
You have a closed system, the energy does not go anywhere. The pressure in such a tire will be off the charts.
That's true. Even if it is a closed system, wouldn't steam help transfer heat out of the carcass and into the rim more effectively, given the better thermal conductivity of steam? Would even just a few centiliters of water send the tyre pressures through the roof?
I can't think of any other reason to do something like this though?
If the water doesn't evaporate, maybe it makes sense to spread the energy throughout the tire and not be contained to a specific part of the tire patch. Still seems like it's just throwing stuff at the wall and seeing what sticks, especially if FIA tried to find evidence of this in Austin and Mexico and couldn't. It should be super simple to detect as tires are closed systems.
Having the accusation being "McLaren and other teams" it is obvious there is no real proof, it's just guesswork.
