Race control as control over the safety car, yellow and red flags during a race etc. When the safety car comes in. Control over the marshals etc. They just follow the rules the FIA gives them.
They had to switch to actual Monza wing here in Vegas, being able to get away with illegal Spa wing in Monza on straights in the race. Speedtrap figuers in Q with DRS are far less important for the influence that wing had. With the Monza wing, they looked way too loose on the rear and definitely looked worse on balance than yesterday.
FIA are not serious people.Vanja #66 wrote: ↑23 Nov 2024, 11:22They had to switch to actual Monza wing here in Vegas, being able to get away with illegal Spa wing in Monza on straights in the race. Speedtrap figuers in Q with DRS are far less important for the influence that wing had. With the Monza wing, they looked way too loose on the rear and definitely looked worse on balance than yesterday.
On their Q3 laps in Vegas, Sainz gained about a tenth on straights vs Norris, while also getting 5 tenths in corners. In Q3 in Monza, Norris gained about 4 tenths on corners vs Leclerc and lost about 2.5 tenths on straights. That's with a new Mexico floor for McLaren and basically the same Ferrari like Monza. So nearly a full second worth of cornering time lost and different balance between illegal Spa wing in Monza and Monza wing in Vegas
Clearly the team that doesn't understand a hard and defined limit like 1mm wear or minimum weight, that everyone knows .... are not serious those are slam dunk infringement, there's no leeway or negotiation, its always been like this. If they ran that risk (the team) , and they clearly did, then they know the penalty. What's not serious in that approach?dialtone wrote: ↑23 Nov 2024, 18:13FIA are not serious people.Vanja #66 wrote: ↑23 Nov 2024, 11:22They had to switch to actual Monza wing here in Vegas, being able to get away with illegal Spa wing in Monza on straights in the race. Speedtrap figuers in Q with DRS are far less important for the influence that wing had. With the Monza wing, they looked way too loose on the rear and definitely looked worse on balance than yesterday.
They DQ Russell for being a bit underweight, DQ Ferrari for 1mm plank wear. Then MCL shows up with a wing that opens 30% when it's not supposed to and whatever, too late to DQ post race.
There must have been though. otherwise the FIA would have introduced new tests or a TD to eliminate the 'loophole'. I believe there is flexible bodywork mentioned in the rules. It was discussed plentiful when it all come to light on here.Farnborough wrote: ↑23 Nov 2024, 18:48
The bending wing, however it's manifested, didn't have enough words in rules to preclude it. Now they all understand the status quo.
I don't think there was a TD or rule change on the RW . FIA just told McLaren to change their wingschrisc90 wrote: ↑23 Nov 2024, 19:00There must have been though. otherwise the FIA would have introduced new tests or a TD to eliminate the 'loophole'. I believe there is flexible bodywork mentioned in the rules. It was discussed plentiful when it all come to light on here.Farnborough wrote: ↑23 Nov 2024, 18:48
Thats the way I seen it too. Which must mean it was contravening a rule already in place. Just the FIA werent checking it. Which is why they got away with it. IMHO.organic wrote: ↑23 Nov 2024, 19:02I don't think there was a TD or rule change on the RW . FIA just told McLaren to change their wingschrisc90 wrote: ↑23 Nov 2024, 19:00There must have been though. otherwise the FIA would have introduced new tests or a TD to eliminate the 'loophole'. I believe there is flexible bodywork mentioned in the rules. It was discussed plentiful when it all come to light on here.Farnborough wrote: ↑23 Nov 2024, 18:48
