2024 car comparison thread
basti313
basti313
Re: 2024 car comparison thread
Triggered by the race in Brazil and this comparison: viewtopic.php?p=1258466#p1258466
I think we still see the evolution of different concepts:
Soft sprung:
2022 RedBull, current Ferrari and McLaren have a relatively "soft" chassis.
Hard sprung:
Mercedes, RedBull. Completely hard, issues on kerbs, but reaches stability on the aero by this measure.
My take on why they are doing this:
With limited wind tunnel time you can not do all runs you want. On a "hard" platform the chassis movement is much less. So you need to do much less wind tunnel experiments with compressed springs.
On the other hand Ferrari and McLaren, being not 2021 WCC contenders always had more freedom to develop in the windtunnel which allows them also for 2023 to stay on a relatively soft platform.
The comparison is not taking this into account...I think when we compare aero values, the platform needs to be taken into account. Hard sprung gives benefits on aero, but kills drivability.
An interesting point in going through some media:
The Intermediate tire changed the benefit of each platform.
Due to the different ride height and the different tire flex hurt the well dialed in concepts of Ferrari and McLaren more than the hard sprung cars of RedBull and Mercedes in the wet.
Don`t russel the hamster!
Farnborough
Farnborough
124
To me (observations given in RB thread) the RB appeared to make use of a very compliant rear suspension in this last, Brazil, race.
I'd not label it with a simple "Hard" philosophy for the evaluation. We've discussed a perception on the RB20 car thread of them running increased static rake, which would facilitate such a rear end setup currently.
This track looked significantly bumpy in latest guise, notably approach to corner one at which many of the chassis had very obvious rigid like movement on the brakes.
A very big bump then drop too coming out of Juncao corner,, through which the RB almost floated.
basti313 wrote:
12 Nov 2024, 10:37
Soft sprung:
Hard sprung:
I think it would be good if we kept talking about suspension stiffness first and foremost :) Chassis stiffness on its own usually means torsional stiffness of the monocoque chassis (bending stiffness is basically a non-issue with CFRP monocoque)
In 2022, all teams tried running much softer suspension in first Barcelona test than they ended up with in Bahrain Q, including Red Bull. It's better ride quality, better kerb riding, better traction etc. When you do that, car starts to bounce around in high-speed sections and especially on straights if you don't lift it up, especially at that time when teams had only a few idea how to mend this issue through aerodynamic design. Overall, it was a better compromise for lap-time to stiffen the car up and run it as low as possible.
In relative terms, RB20 has a very stiff front and it's limiting their kerb riding and bump response. Ferrari and McLaren are indeed fairly soft in comparison, while Mercedes is hard to figure out exactly (for me at least) as they seem to be changing bulk of the car and its characteristic with every update. Whatever the case, I don't think it has anything to do with WT and aero testing and making shortcuts. All these cars are still very high when standing still, so you still need to run loads of reference cases for each ride height.
Instead, I think it's simply about core concept of every car. I don't agree RB18 was soft, although it had a softer rear (in relative terms) than RB19, it was still a very stiff car that was able to nurse the tyres very well in every race of the season. All 3 Ferrari cars so far were softer than RB and even when you compare 2022 and 2024 Monaco pole laps of Leclerc, you'll see SF24 is clearly the softer of the two. F1-75 was running quite high all the time and it still had a lot of floor downforce, so even though it was bouncing on straights it wasn't wearing the plank and it wasn't bottoming out. Other than Barcelona-spec floor, SF24 has bouncing under control but they had to take some measures to mitigate aerodynamic part of the bouncing issues with Monza floor, namely by discarding vertical kicks on the keel - but also by making big changes to the floor edge. All those changes definitely cost them raw downforce, but they got a floor that can probably use all the downforce it can generate across the lap.
Intermediates in Brasil race were peculiar as far as McLaren goes, they still got the pole lap on those and it really should have been a 1-2 for them in my view. Norris was running in dirty air all the time, so was Piastri, they were making mistakes and I honestly don't think it was down to the car for McLaren. For Ferrari, the car is not able to generate heat in the tyres quickly and this hurt them both in Q and R in Brasil. Leclerc never had a decent clean run on Inters in Q2 and Q3, somehow he had to abort half the laps in Q2 and Q3 due to incidents and red flags and this never helped getting those Inters in the right window. On top of that, they admit they made a mistake with setup and they also gambled on different outcome for rain during the race and how they used their tyres.
On the other hand, Mercedes lights up the tyres right away and they were always good in the wet and cold sessions this year. RB20 also lights up the tyres quickly, but it has a much better deg curve in the race than Mercs. Getting tyres in the window and keeping them there is far more important than ride height in the wet if you ask me. All corners are run much slower (some of them over 50kmh slower in Brasil) so the downforce contribution is much, much lower than tyre grip compared to dry conditions.
basti313
basti313
Vanja #66 wrote:
12 Nov 2024, 12:04
Yes, sorry I am more used to take the discussion on the full chassis. You are 100% right for F1.
Vanja #66 wrote:
12 Nov 2024, 12:04
On the front there are comparison videos, on the RB18 you could see the upper wishbone moving, on the RB19 it is just stiff.
But I refer more to the rear: I think the RB18 rear was higher with more suspension travel similar to what Ferrari and McLaren do. For the RB19 they changed the rear suspension as far as I can remember it to a more Mercedes like low rear with low travel. This is why I assume that both cars share similar issues.
Vanja #66 wrote:
12 Nov 2024, 12:04
Mmmhh....I agree on the restarts. There even Perez was "there" after the last SC restart and Russel was always better then Lec and Nor.
I disagree on the laps not too soon after that. I do not believe, that the tire is not up to temperature during 20? laps at racing speed.
Both Russel and Verstappen had much better laptimes consistently...I do not believe that this was purely driver magic or the tire. The aero was also better than what we saw the last races.
basti313 wrote:
12 Nov 2024, 16:13
It's not easy to connect all the dots, not even for teams. For instance, if you remember Leclerc took 2-3 cars into T1 on final restart, including Russell. It wasn't because of tyre temps, he took the best track position and had no spray into his face. He could judge clearly when to break exactly and had a clear view of the line.
Later, he made a mistake and Russell overtook him and that was about it of his race. Both him and Vasseur confirmed they made the wrong setup choice on Sunday morningNorris also kept making mistakes, McLaren definitely seems to hurt quite a lot in dirty air, more than others. Driver feel and confidence is key in the wet, getting tyres in the window is a huge factor. It's not all obviously, good setup and driver himself are very important and a brave driver can bring maybe even seconds in the wet even with modern cars where tenths are huge in grid order.
Some Italian outlets said Ferrari made the car too soft on Sunday and the floor was too unstable in the race for either driver to get into any kind of rhythm. On the other hand, Alpine drivers said they kept the dry setup for Sunday. Both of these cases make very little sense in general, but with these cars and how important it is to keep the floor in the window - anything is possible.
basti313
basti313
Vanja #66 wrote:
12 Nov 2024, 17:57
basti313 wrote:
12 Nov 2024, 16:13
I get your point, but saying everything in performance swing we saw is setup related is ... boring. :wink:
I buy the fact that Ferrari claims their setup was wrong only partially. It could still read, that the raise of ride height coming from the Inter was a big part of this.
I do not buy it at McLaren, that the only team that nailed every setup since Miami is now screwing up the setup? On a weekend where they do nothing else but play it safe?
Unfortunately we do not have a Q to compare, this was a mess and the McLarens and Russel were the only ones getting a Q3 lap time without issues.
I like your point on the Alpine. So the Alpine is also on the rather "hard" side? How about the RB? Do they have the RedBull rear suspension? Mmhhhh...sounds like a coincidence to me.
For the comparison of performance:
I am looking at the last stint. There all relevant drivers except Perez and Hamilton have a lot of free air. Norris quite quickly dropped more than a second (1.5) behind Leclerc after the switch with Piastri, Russel was quickly far ahead of Lec. So everyone had enough free air for the drying track. Ferrari and McLaren had a very similar pace just like the races before.
There was only a big swing in performance towards RedBull and Mercedes, obviously completely opposite to what we saw now in many races before.
In the midfield I would add the same swing for Haas vs. their peer group...
Farnborough
Farnborough
124
"think it would be good if we kept talking about suspension stiffness first and foremost :) Chassis stiffness on its own usually means torsional stiffness of the monocoque chassis (bending stiffness is basically a non-issue with CFRP monocoque)"
I can see this view and agree with it too, but would offer something in the way of MB approach that just could be different. Speculation? Definitely on my part, but with some reasoning.
It LOOKS very, very awkward, continually, and obviously they've got nowhere near bringing consistent and repeatable performance.
ALMOST reminiscent of a kart chassis that uses torsional flex to accommodate load interface with ground topography. Something AN tried when at Williams I believe. It "bounces" load into its tires with particular ferocity, and with Lewis comments of three wheeling, hopping inside front, knife edge at limit for both driver, looks like they've extremely limited options apart from ride height preference.
This is quite interesting as a good visual of particularly unyielding suspension and high staccato load into tire carcass, timeline 1:20 particularly
Another very weird chassis in characteristics, related to torsional integrity too, was the Renault with wide angle V engine block (driven by JB, I think) that was equally "impressive " in its ability to not perform. Thought that one was pinching crank bearings too in it's block flexing :shock:
I'm not suggesting the motor in this case, but maybe a monocoque torsional level that would have potential to work with a kart like "intention " while utilising very high suspension stiffness. It's really puzzling they don't actually get anywhere with this series of car, given the facilities and capability in place.
basti313 wrote:
12 Nov 2024, 21:13
Ahaha, I feel with you :mrgreen: I feel I may have mislead you, putting emphasis on tyre treatment and whether a car instantly lights them up or gently warms them up. As far as I know this is actually related directly, although not only, to suspension stiffness. Stiffer suspension will put more energy into the tyre, simply because it doesn't take any inertial energy of sprung mass onto itself. So indeed, like you said, stiffer car overall plays a role with tyre temperature and it may have benefited some cars.
basti313 wrote:
12 Nov 2024, 21:13
I don't think so. Wets are even taller and Leclerc was excellent on wets in Q1 and early Q2. Whenever there are bumps where cars need to be lifted up on track to prevent plank damage, Ferrari excels. SF24 responds well to high ride heights, just like previous two cars in general. If they indeed went with softer setup for Q and R, it would also be critical in the race for the reason mentioned above - softer suspension doesn't leave too much energy for tyres themselves. So in addition to having a suspension geometry that nurses tyres, you don't give them enough energy through softer setup and you end up with a floor that leaves its optimal window too often during the race - a recipe for disaster, no wonder Leclerc blames himself for going that way with setup
basti313 wrote:
12 Nov 2024, 21:13
No, I don't think McLaren messed the setup. I think Norris was too cautious and after the red flag he was probably fuming to see Verstappen ahead and after several mistakes he completely lost his confidence. Piastri also made mistakes and was always in dirty air so he lost time there too. Like I said, it really should have been an easy 1-2 for McLaren no matter wet or dry.
basti313 wrote:
12 Nov 2024, 21:13
No idea about the Alpine car in general, I only read about their setup on the race thread :)
basti313 wrote:
12 Nov 2024, 21:13
To be honest, I fully expected a strong Russell in the wet and he really was very strong overall. Verstappen was very strong in dry SQ and Sprint, so I wouldn't say there was a big performance swing for RB20...
Farnborough
Farnborough
124
"I don't think so. Wets are even taller and Leclerc was excellent on wets in Q1 and early Q2. Whenever there are bumps where cars need to be lifted up on track to prevent plank damage, Ferrari excels. SF24 responds well to high ride heights, just like previous two cars in general. If they indeed went with softer setup for Q and R, it would also be critical in the race for the reason mentioned above - softer suspension doesn't leave too much energy for tyres themselves. So in addition to having a suspension geometry that nurses tyres, you don't give them enough energy through softer setup and you end up with a floor that leaves its optimal window too often during the race - a recipe for disaster, no wonder Leclerc blames himself for going that way with setup"
I doesn't work like that, i understand.
Higher load , from aero, is countered by stronger (higher poundage) spring rates, to enact that raised load onto the tire structure.
There's a saying used over the years "show me a car that both heats its tires well, and maintains the tire life, then I'll show you a car that generates a high download"
Download is absolutely king in almost every aspect of these (any aero formula) with MOST shortcomings being because you can't get enough.
Except Mercedes, that is :mrgreen:
KimiRai
KimiRai
301
carisi2k
What about the sprint race temp wins and the Qatar GP?
Farnborough
Farnborough
124
Ultimately it's logical i considering the ambient temperature etc, but looks like that's possibly a formulaic view and attempting to attach performance to a metric that may not be the source.
Undoubted that a whole range of performance issues are significantly affected by temperature interaction.
The root cause maybe something different in driving that though. It could serve well to examine other aspect that also plays considerably in the influence sphere that drives ultimate tire performance in relation to each chassis and aero platform.
Something making the same comparison but using static start pressure for each GP would be interesting, then to cross reference with this example above to understand if there's logical correlation that could produce a more resolved image of this performance area.
Tire pressure is used to control heat range in tire structures when subjected to load, a profound influence on how these cars can both generate heat and use that in their own performance envelope.
