Low-speed analysis
So far, I didn't see McLaren having a clear obvious static rake angle like SF25 does, but with excellent traction it goes without saying they can't avoid softer suspension in the 1st phase of non-linear spring compression and therefore likely a slightly higher rear end in low-speed sections
Medium-speed analysis
Both front and rear end of the floor get a boost, but I believe the rear end gets more, as diffuser kick also represents the floor throat on McLaren. Additionally, their side and rear boat keel kicks start yielding bigger gains at these speeds and ride-height ranges
High-speed analysis
Finally, at extreme low ride heights, the diffuser kick becomes the definitive downforce peak point - hence the amazing high-speed performance and rear-end stability on McLaren cars for almost two years now
As for boat keel kicks, I believe McLaren lets them stall locally to shed some downforce, but prevents stall propagation as the lateral flow from the side of the boat section starts taking the place of the flow from the bottom. McLaren often sparks quite heavily on straights and high-speed corners at low fuel, so it's difficult to imagine the lowest section of the floor and those kicks aren't stalled when the ride height oscillates with small amplitudes.
