2025 McLaren F1 Team
Macklaren
Macklaren
Re: 2025 McLaren F1 Team
FittingMechanics wrote:
14 Mar 2025, 13:35
Thank you for that comparison between PIA and LEC.
It is good to see how there is no "engine mode difference" when you compare PIA to LEC. I'm mentioning this because some commentators were saying that NOR was on higher engine mode because he was faster on the back straight. PIA trace shows that this is probably just an artifact of NOR running a smaller rear wing, so NOR gains on the straights but can't carry as much speed in the corner.
Didn't they have the same rear wing for FP2? NOR was clearly skinnier for FP1 though
FittingMechanics
FittingMechanics
Macklaren wrote:
14 Mar 2025, 14:17
14 Mar 2025, 13:35
Looking at F1-tempo you are probably right. Apologies for the confusion.
Dafnalina
Dafnalina
So Norris had a higher engine mode than both Lec and Pia?
He seems a lot more pessimistic about the balance of the car, but he says it was the same in Bahrain. Let's hope it has some window for the setup and it's not RB 2.0. This is the first fully Rob Marshall car, and I'm kind of scared. Oscar said the car felt a lot different than last year's
f1rules
f1rules
621
Toto Wolff: “McLaren is at the front. Then all the others come in line.”
Macklaren
Macklaren
Dafnalina wrote:
14 Mar 2025, 16:13
He's def talking down expectations. Though it could be setup differences because of the weather as well. I expect McLaren to walk it in a normal race
FittingMechanics
FittingMechanics
Dafnalina wrote:
14 Mar 2025, 16:13
I still expect pole tomorrow.
SilviuAgo
mwillems wrote:
14 Mar 2025, 13:29
The DRS Delta disagrees with the top speeds. Was that top speeds on fastest lap? When looking at that data, we are only behind 4 teams on top speed.
Also for me was an inconsistence in the values and I put both sources to have the info. As you said, if we look at MCL39, we are not far behind as was the case usually on 2024 Fridays.
Regarding the size of the RW, I found an excellent post from our forum colleague Vanja, with McLaren continuing this weekend with bigger wing from the 2 options tested during Fp1.
mwillems
45
Nice, thank-you. We are indeed running the bigger wing and still doing well.
12 hours till we see how the car runs in anger. Toto think we're miles away, Marko thinks it's close and Lando thinks the car is a handful. All have reasons to exaggerate. We will soon know.
Just a shame FP3 is at 1am here, and Q in early morning.
-Bandit
Darth-Piekus
-1
Unless this is the true pace of both competitors I hope Mclaren opens up the engine to full and take an emphatic front row lockout. I wont watch the qualifying or the race as its too early for me but in any case good luck to the team and may we have as good of a start of the season as possible.
djos
113
I was lucky enough to spend an hour in the pit lane last night, I took some pics of the McLaren garage you guys might like.
https://imgur.com/a/ByUCY7c
"In downforce we trust"
Slahinki
Slahinki
1 and 3 after the opening laps, not bad at all.
Darth-Piekus
-1
Q1 ended and it's so close that just a tenth sends you 3 or 4 positions down. One Red Bull and one Mercedes out of Q2. We need both drivers to do 1.15.7 for an 1-2.
mwillems
45
Well that was close, until.it wasn't!
Great job by the boys.
No issues with the rear.
-Bandit
Mostlyeels
Mostlyeels
Smashed it in quali!
Slahinki
Slahinki
That's a 1-2! Excellent work by the team, Lando and Oscar. Our slowest car being 3 tenths up on third place is a good start to the qualifying record for the season.
