[MVRC] Mantium Virtual Racecar Challenge 2025 (Grand Prix Cars)
yinlad
33
Re: [MVRC] Mantium Virtual Racecar Challenge 2025 (Grand Prix Cars)
The Rusted One wrote:
02 Apr 2025, 18:12
yinlad wrote:
02 Apr 2025, 10:39
Re the floor : "when cut by any Z-plane in the interval Z = (35mm, 275mm) produce up to two sections."
Could someone clarify if this per side or across the entire floor, and what the intent of the rule is? Because with how far down the diffuser fences come you run into 3 sections between the floor boat and diffuser walls by default, rather than through some effort to exploit something.
From my understanding, that rule is only aimed at the floor body, so its two sections not including the floor fence.
Yeah I know, the point stands that you can end up with 3 sections made up of diffuser walls and floor boat, 5 sections if you included diffuser fences. Unless its per half car instead of per full car.
This is what I mean. If that is how it is, that's ok. I just wanted to get clarification so I know if I need to manage the overlap between the floor ramp under the gearbox and the 15mm of protruding diffuser wall we get
MVRC - Panthera
Ft5fTL
26
It's a bit off topic but need to ask. I installed ubuntu on one of my drivers for mvrc stuff but i could not manage to open my case on mflow. Therefore i cannot create the case file and start the simulation. Do i need additional things to install before using mflow on ubuntu?
Mantium Challenge - Pure Power Racing
spacehead3
yinlad wrote:
02 Apr 2025, 18:18
I'm seeing the bottom of the diffuser walls even with the 35mm plane, so there is no intersection between those surfaces.
Max Taylor
yinlad
33
spacehead3 wrote:
02 Apr 2025, 18:49
yinlad wrote:
02 Apr 2025, 18:18
Not sure I follow. This is a slice of a floor at Z = 45, due to the diffuser I have 3 sections within a region of Z that the maximum allowed is 2.
MVRC - Panthera
spacehead3
yinlad wrote:
02 Apr 2025, 20:39
Ah, yeah you're right #-o
Max Taylor
Koldskaal
25
yinlad wrote:
02 Apr 2025, 10:39
The rules always apply to the whole car, unless explicitly stated otherwise.
The diffuser fences are not included in this rule.
Regarding the three Z-sections of the floor: I think this is just an oversight from adapting the f1 rules to mvrc. In the f1 rules the diffuser-sidewalls are treated as seperate parts. So they wouldn't contribute to the number of Z-sections of the floor-body. The sidewall has its own rules:
Perhaps it was a mistake to merge with the sidewall with the floor-body. What do you guys think? should we make the number of sections rule only apply above Z=50mm? or more realistically make the diffuser sidewall a seperate part with its own rules?
MVRC - Koldskaal, name: Christian
LVDH
46
Ft5fTL wrote:
02 Apr 2025, 18:22
This is not quite enough information to help you. Best is you go here:
https://mantiumflow.com/mantiumflow-cfd ... e-support/
Either you find a solution there, or we will create one for others to then also be able to find.
Rules are making good progress, maybe tomorrow we can announce something that will be "final".
yinlad
33
LVDH wrote:
04 Apr 2025, 16:37
Ft5fTL wrote:
02 Apr 2025, 18:22
Good you know, thanks! I've been making some progress on next(this?) year's car, though I keep encountering legality issues and then lose all the performance I gained making it legal again 😂
I can't say I'm feeling particularly confident with the performance I've managed to extract so far, but in comparison to the end of last year we had some absolute monster numbers coming out of the cars
MVRC - Panthera
LVDH
46
So, there are updated rules, parts and MFlow available on the page.
Please everybody have a look.
For race 2, we will introduce a rule to limit curvature on parts such as the engine cover. Right now, this is taken care of by rule 9.8.
Also, I am wondering about how many of you have used the autoScrut tool by Christian. It is very good, he did a very good job. To use it, you have to install Python and some additional libraries. This might not be everyone's cup of tee, so I am wondering, if we should provide executables, just like with MFlow. But if nobody uses it, then I can invest my time on other aspects of MVRC.
k.ko100v
k.ko100v
16
LVDH wrote:
07 Apr 2025, 14:30
So, there are updated rules...
Do you think the floor_led (leading edge device) should also be included in the high-resolution folder?
I’ve noticed that the generated vortices are not as well-developed in the fast simulation. In contrast, in the normal simulation—where the cell size is smaller (0.5 vs. 0.75 in fast)—they appear much more developed, which would likely lead to a more accurate representation of their impact.
Regarding the new version of MFlow, I assume it won’t work under blueCFD. My question is: if I continue using my current version (v2403), what would be the impact? Would the results be less representative, or would I simply miss out on the new graphical features?
Regards,
Krasen
