As our Moderator, Ciro, has attempted to point out, this thread is not for discussing anything but the technical development of the car.
Please listen, and let this post be a line in the sand, thanks.
looking at the bottom pic of the front brake assembly it seems there is a secodary air intake feeding air to the brake caliper... I haven't noticed any discussion of this in this, or other threads, (but accept I m ight have missed it!)... is this unique to Macca??bar555 wrote:EXHAUSTS - SINGAPORE
DIFFUSER - SINGAPORE
FRONT BRAKES - SINGAPORE
I'm also curious as to what all the sensors are.Mikey_s wrote:Also... there are a lot of sensors feeding through hthe upper wishbone - anyone care to speculate on what these are measuring... Temperature is a obvious candidate, wear of the disc/calipers another... but there seem to be planty of sensors there...
Oh yes, there's the big air scoop and below there is a little pencil thin periscope of an air duct. I wonnder what that is for.Mikey_s wrote:looking at the bottom pic of the front brake assembly it seems there is a secodary air intake feeding air to the brake caliper... I haven't noticed any discussion of this in this, or other threads, (but accept I m ight have missed it!)... is this unique to Macca??
There would also be an receiver for a "pickup" of the internal tire air pressure located in this area, as it's transmitted by wireless through the wheel... the "accurate" range for the receiver is 2 feet unless that has been improved in recent years and can be put on the chassis, some 3.5 feet away.goony wrote:wheel speed brake wear and temp
if u can find sum pics of the mirrors we had thermal imaging cams in them for a time to check tyre temp on the go
goony
thanks speedsense ,speedsense wrote: I too would like to thank BAR555 for the great posts this year hopefully you will do the same next year.... great job!!
x 2Mikey_s wrote:bar,
I have no idea where you ge the pics or where you find the time to do what you do, but it is great and thanks for doing it.
Fantastic effort.
X3 Pics are unbelievable!!!richard_leeds wrote:x 2Mikey_s wrote:bar,
Fantastic effort.
