Well, you're late, it was already debunked. Salt water as fuelxpensive wrote:If everybody's done with the teriffic transmissions, can I please have my own thread on my water-fueled engine now, Ciro?
Can't tell you how it works, but is ok to run on seawater.
So, as nitpicky as I have become about insults, I'm all in for trying crazy ideas. I trust the judgement of the forum, each day a little more, specially after watching the skepticism displayed by bazanaius and yourself, following an illustrious list of predecessors: well done.During an interview with a newspaper reporter recently, I was asked a common question: "Do you feel like we're losing the battle? That people are increasingly turning away from science and towards woo-woo?" And I answered, as I always answer, "No."
--James Randi--
Slaughtering unicorns is not very green is it now. Besides, aren't they on the endangered species list?MinacciolMotors wrote:OMG!! NEW IDEA!! Let's make an engine that uses the laughter of your children to ignite everlasting combustion of unicorn blood!! It's soooooo efficient!!
A friend of mine built the first slot car racing cars long before Scalextric in 1940. The British bomber crews used to play on it between raids on Germany.flynfrog wrote:there is really no need for gears in the next gen cars you could simply change the motor timing and or the coil wiring on the fly. And unlike autogyro Ive raced it and won.
Sorry the answer is yes.MinacciolMotors wrote:Haha. That's an easy one autogyro. The answer is false. Adding a transmission decreases efficiency when you only have one gear because there is friction, which is wasted energy. However, by adding multiple gears, you can increase efficiency by using less power for higher revolutions by multiplying crank speeds. Also, a transmission for an electric motor deals with constant, and ridiculous I might add, torque. Very different than a conventional IC tranny.
They can if you have a motor that doesn’t have a large efficient rev range. But you also lose drive line efficiency its a balancing act. The car I raced was a little clunky off the line with the motor cogging but from 25 - 80 mph was 95-98% to the ground. Show me a gear box that can do that.autogyro wrote:A friend of mine built the first slot car racing cars long before Scalextric in 1940. The British bomber crews used to play on it between raids on Germany.flynfrog wrote:there is really no need for gears in the next gen cars you could simply change the motor timing and or the coil wiring on the fly. And unlike autogyro Ive raced it and won.
True or False?
autogyro wrote:Not much good in traffic then flyn?
I had a Ford Cortina Savage with a 351 Cleveland V8 and 500 bhp years ago.
I used it for towing after we had won everything in super with it.
That car would take off in top gear and go all the way to 140mph.
Top was good enough for town work as well.
