i was searching around for some other detail shots from the BGP001, and i found this weird thing:
as seen in the pic there is a hole in the sidepod, is this a turning vane, cooling or am i seeing it wrong?
Are you talking the thing top right? I'm pretty sure that is a reflection. If you use an arrow, we'll know what you're refering to.wesley123 wrote:i was searching around for some other detail shots from the BGP001, and i found this weird thing:
going by the colour of the road, it looks like this photo is taken in the pits. if the photographer is facing the pit facilities, the light is from above/inside one of the pit boxes.BreezyRacer wrote:I would like to know where that light is coming from shining on top of the splitter .. or if it's not a light what is it?
No the scruffy black bodywork\opening in the middle below that lineFil wrote:are we talking about the faint line extending from both bolt-holes on the sidepod?
ESPImperium wrote:From what ive been reading in Jenson Button: My Championship Year and F1 Racing (December 09 or January 10 issue, i cannot remember whitch one) that the Brawn BGP001 could have been up to 3 seconds faster than it actually was if it;
1) Was designed for the Mercedes Benz FO108W as the centre of gravity was raised about 2-3CM and the CoG for the gearbox was raised up to 4CM as well. Not to mention the 20KG extra carbon work that was at the back of the chassis to accomidate the FO108Ws power unit.
2) Aero work could have been better, again relating to the Mercedes unit.
3) Nosecone - Could have been developed futher and exploit the rules more to give better aero efficency.
4) Heat Generation in tyres. If this was resolved, the car could have been up with the Red Bull RB5 on colder days.
6) Rear wing - They only produced 3 types all season, about 14-18 in total, as they couldnt use what they had found in the tunnel and CFD due to budget constraints.
7) KERS - The RA109 was to have KERS for the RA807E powerplant, all to be housed below the drivers seat, but for the FO108W, they housed the oil tank here, and the KERS batteries would have gone here for the Mercedes unit. However, the control unit would have required a air cooling element to be added for the Mercedes unit.
Budget, if the yearly budget wasnt a rumored £110million and was the £400million that Honda were going to allocate, things would have been alot easier overall.
Basically if the whole car was designed for the Mercedes unit from Day 1, and not for the Honda unit, the BGP001 would have been about 2-3 seconds a lap faster. All things considered.
