In the article Whitmarsh says that Hamilton and Jenson Both have a neutral style..
But for argument sake, we must think of some problems:
How does Mclaren Design a car for Lewis Hamilton/Jenson Button? Would they not make the car as best as possible first then give Lewis and Jenson it to test?
With these new regulations for next year, how can an engineer quantify a drivers style to use as input into designing a new car?
Even AFTER the car is made and tested by Lewis and Jenson, and the engineers analyse data from each driver, what sort of things can be adjusted if: one driver is unhappy, or both drivers are unhappy?
*My conclusion is that the priority is to extract the maximum performance from the machine. The style of a driver is just a series of different inputs into the control system that is the car. These inputs already lie in the range of possibilities and have already been accounted for. All control systems have ONE optimal behaviour for a certain task. It is just a matter of luck or sheer talent if the driver has a style or can adapt his style to operate the machine in the optimal state.
OK..I never went to control systems class much.. but here is something about optimal control on Wiki, and look at the shining example..
http://en.wikipedia.org/wiki/Optimal_control
Optimal control deals with the problem of finding a control law for a given system such that a certain optimality criterion is achieved. A control problem includes a cost functional that is a function of state and control variables. An optimal control is a set of differential equations describing the paths of the control variables that minimize the cost functional. The optimal control can be derived using Pontryagin's maximum principle (a necessary condition), or by solving the Hamilton-Jacobi-Bellman equation (a sufficient condition).
We begin with a simple example. Consider a car traveling on a straight line through a hilly road. The question is, how should the driver press the accelerator pedal in order to minimize the total traveling time? Clearly in this example, the term control law refers specifically to the way in which the driver presses the accelerator and shifts the gears. The "system" consists of both the car and the road, and the optimality criterion is the minimization of the total traveling time. Control problems usually include ancillary constraints. For example the amount of available fuel might be limited, the accelerator pedal cannot be pushed through the floor of the car, speed limits, etc.
A proper cost functional is a mathematical expression giving the traveling time as a function of the speed, geometrical considerations, and initial conditions of the system. It is often the case that the constraints are interchangeable with the cost functional.
Another optimal control problem is to find the way to drive the car so as to minimize its fuel consumption, given that it must complete a given course in a time not exceeding some amount. Yet another control problem is to minimize the total monetary cost of completing the trip, given assumed monetary prices for time and fuel
I don't know what the rest of the article is saying..lol but I hope you understand my thinking.
The words in red has me thinking. I think driving say, the RedBull car into say Q3 in AbuDahbi will be in the "sufficient" category. But notice, that to get the perfect lap using the peak of the cars performance would be in the "necessary" category. In other words there is only ONE NECESSARY combination of driving to make the car drive at 100%. To figure out that combination is up to the driver. That alone can separate The two drivers.
Remember I am talking about a car that is OPTIMISED it can not get any better no matter what!
Another example, One driver is only doing enough to get through and his fans will be complaining that the car was not made for him. While the other driver is more versatile and/or intelligent and realises what necessary changes in his driving style must be made to meet the optimal performance. The second driver will beat his team mate all the time because he has unlocked "the secrets" of the car; he is on or near to the optimal combination "pathway".
