xpensive wrote:OK. Your graph explains the reason for wheel-spin from zero speed as wheel-torque from 480kW becomes theoretically enormous at very low speeds. If we would toy with the idea of a mu of 2.5 and a rear wheel contact-load of 5 kN, maximum thrust is then 12.5 kN, which equals a wheel-torque of 4125 Nm with the 660 mm wheels.
Still with 480 kW of power, said thrust would be at 38.4 m/s, or 138 km/h.
In other words, under the above conditions with 480 kW applied all the way, the F1 car would have wheel-spin up to the speed of 138 km/h, is that reasonable?
Is the mu of 2.5 that of pure sliding friction or rolling?
I have a feeling this coefficient is this high because it may represent static wheels scraping along a surface, (braking coefficient like in a lock up) instead of rolling with localized slippage and deformation at the contact patch.
The wheel torque has to be a limiting value, it must not be worked back from another equation.
As you know, torque is limited to the gearing at what ever road speed and engine speed. So it should be like a given parameter.
From dyno chart, you have power and torque at what ever speed you want.
you know your torque to the wheel axle; only the engine can change this, anything more will decelerate or just stall the engine. ie if mu is increased to the point where the engine cannot deliver it will simply stall, kind of like a big load on an electric circuit.
this is how i suppose could work,
Power = T x omega (angular velocity), (1)
Torque = radius of wheel x Force at radius (2)
omega = rpm/60, = V wheel (V road x slip) / wheel radius
Net Thrust = Force at radius (using 2)- rolling resistance at wheels ( reaction force x coef of rolling resistance)
Net Thrust x wheel radius = I wheel x angular accel, (I = second moment of inertia , alpha = r x accel at road.)
at top speed, drag force = thrust, no acceleration so alpha = 0
from this: thrust x wheel radius = I x alpha = 0
so it follows, 0 = (force at radius - rolling resistance) x radius
the torque to the wheels balances the rolling resistance. The torque component of the engine is still there working to stay up to speed, just within the wheel system.
