F1 suspensions
darksag3x
F1 suspensions
is it possible for F1 cars to entirely not have suspensions (like go-karts)? any advantages or disadvantges to this?
manchild
manchild
Go-karts have no suspension because they are so lightweight and that allows their tyre pressure to be around 0.7 which enables some absorption capabilities. F1 has 605 kg… end of story.
Guest
Guest
if F1 cars were lighter, would a suspension-less design benefit handling in any way?
manchild
manchild
Well, you have to observe the F1 car as large go-kart. It weights as much as it does and suspension it currently has is as stiff as possible. It would have to weight as much as real go-kart to so that suspension-less design can be concerned.
RH1300S
RH1300S
It's more subtle than that.
Karts have a degree of suspension by controlled flex of the chassis, which can be tuned to different tracks. I don't know the rules, but I suspect that the reason karts don't have suspension is that it is part of the rules package and the makers use chassis flex and steering geometry to minimise the disadvantages of a rigid chassis.
The main purpose of suspension in an F1 car is to manage weight transfer (amount and speed of....) and help the tyres do their job. With a suspension system the engineers can adjust and balance the car to track conditions and to affect behaviours to make the drivers job easier. Also, suspension systems let them pay careful attention to ride height and pitch to get the most out of the aero package.
manchild
manchild
F1 chassis would also flex if it was suspension-less in a way that it resembles on go-kart with wheels attached to the four corners of the chassis. Or, it can be said that go-kart chassis is made deliberately flexible which is something F1 can’t afford just as it can’t afford low pressure tyres for same purpose.
Anyway I think that talking about this is pointless since it is so far from reality.
Guest
Guest
Doesnt that depend on the construction of the tire(low pressure) ?
But surely the cars are built as stiff as possible to allow the suspension to be more precise ?
/ Fx
Steven
Owner
I think a suspension less car was once tried by Colin Chapman at Lotus.
Can't find it at the moment but I think I can recall something about the cars being too demanding for the drivers.
DaveKillens
DaveKillens
34
Unless you race on a billiard table, you need some form of "suspension". As a tire contacts a road irregularity, be it a depression or a dip, it can lose contact with the road surface. If you're not in contact, you're not in control, nor are you going as fast as you can. Also, any movement by the chassis would impart geometry change or vector forces that could be undesirable.
When you discuss suspensions, two important parameters are unsprung weight and sprung weight. The broad idea is to have the unsprung weight of the wheels and suspension uprights, shocks, etc. have as low mass as possible, and follow the road surfact, while allowing the sprung weight (chassis) to ride along unbothered. The chassis, where the suspension components locate, is usually as rigid as possible, not only for safety, but to be consistent, so that the suspension isn't subject to unwanted forces. I really put it in simplistit terms, but you have to have a stiff chassis, and you have to allow the wheels to move independant of the chassis to have proper performance.
As mentioned in previous posts, karts have some form or partial suspension action, even though the chassis and wheels are rigidly mounted to each other. It's good enough for the speeds and surfaces they run on, and hey, one of the appeals of karts is that they are simple.
manchild
manchild
Tomba wrote:I think a suspension less car was once tried by Colin Chapman at Lotus.
I think that it had suspension but incorporating aerodynamics and body work sprung separately from the cockpit.
Is this the one? Lotus 86
darksag3x
is steering response and handling better or worse on the kart because of its suspension-less design?
manchild
manchild
It is best possible according to specific regulations. In general, go-kart’s steering response and handling is completely different because there is no differential on the rear axle and that makes huge difference in driving style.
Steven
Owner
No it is not, the car you refer to is actually a Lotus 88 to be found here:
http://www.f1technical.net/f1db/cars/473
However, I was thinking of something else :)
manchild
manchild
Lotus on photo I linked is Lotus 86, that is the car that never raced while Lotus 88 raced (car on your photo).
http://8w.forix.com/6thgear/neverraced.html
Experimental dual-chassis car based on Lotus 81. Completed in autumn of 1980. Was tested but never raced
RH1300S
RH1300S
darksag3x wrote:is steering response and handling better or worse on the kart because of its suspension-less design?
No, it's because they weigh nothing, have short wheel base and less track width. Turn like a fly........
Put it in a high speed corner and you have a whole new set of problems
