segedunum wrote:No, that's not how it works. While a F-22 might not be designed with one pilot in mind that does not mean that it doesn't favour a certain group of pilots who like to do certain things, and in reality, once it's up in the air, that's what counts. Besides, it has to cater to a large cross-section of pilots whereas a car caters to one or two drivers, so no, the comparison is not really accurate.ringo wrote:Diesel is correct. The car is not designed for a driver style, that's like saying an f22 raptor was designed for an individual pilot's flying style.
It certainly does. Once a driver says "I want a car that does this...." it certainly heavily influences the way that future cars on the drawing board are designed. The longer a driver is around the more ingrained that becomes. You cannot just pluck a car built with a certain philosophy and have the driver muck about with the set up for several months trying to get the car to overcome its natural tendencies. It just wouldn't be a sensible thing to do to go against that.This was discussed already and i think we came to the conclusion that a driver's style does not influence the design process of the car.
This was explained above.
You don't build a car from scratch. You use the sum of your experiences, you use the experience of previous set ups and you use the experience of what you were trying to get the car to do when you went through those. Yes, a driver's style is quantifiable because it is the sum of all of those things (certainly if he's winning) - and that goes into the design of the next car, whether knowingly or unknowingly.A driver's style is not something quantifiable, so it cannot be a parameter for actually building the car from scratch.
The car never ends up being neutral when it gets on to the track and is driven and the driver has input, that's the bottom line. It either has a natural tendency to one side or the other as a driver gets it to do certain things to gain an advantage, and that's where it starts favouring a certain driver's style. That's the only way you can gain an advantage.The car is designed neutral, similar to a fighter plane.
Fighter planes also aren't designed to be neutral. They are designed to be somewhat unstable to gave them an edge in agility.
Repeating that a car is designed to be neutral won't stop it from favouring the style and tendencies of one driver over another. We've seen this time and time again and results also bear it out.
i apologise up front, but segedunum, an F1 car is not designed to oversteer or understeer. It is designed to lean more in one direction than another through built in suspension adjustments that allows the car to be set up for a particular driver.
every designer aims for as neutral a car as they can design and to cater for a tyre characteristic that needs to be favoured.
They favour neutral because it represents the best controlled characteristic and development starting point.
Rory Byrne always aimed to design the most neutral car he could. The fact that schumacher could cope with an oversteering set up is a driver characteristic that can be catered for a neutral well balanced car. The same car will also be able to be configured for a understeer preference aka. Renault's 05 and 06 title winning cars.
Adrian Newey also designs cars to be neutral. Thats his starting point. not over steer, not understeer, not mid corner unstable, not corner entry unstable or exit unstable, a designer also does nto design a car to pitch senstive (which hampers stability under braking), they design cars to be neutral.
Often a car does not emerge from production quite as intended. thats when a driver ho can drive around a characteristic and still achieve lap times is worth their weight in gold.
even Mr. Schumacher prefers a neutral car, so does Mr. Alonso and Mr Massa and Mr. Hamilton Jnr.
So please, long winded posts is not going to alter this fact.
F1 cars are designed to be neutral but to have sufficient adjustibility in them to cater for drivers leaning toward either a bit of oversteer or a bit of understeer.
Most prefer a hint of safe understeer btw.
under 2010 rules with the narrow front tyre, you will find that drivers with a preference toward a slight oversteer will get more from their tyres because these will determine wear rates. There is usfficient ballast to move around to acheive that inconjunction with suspension settings.
but the cars still start life, in the software as neutral.
