Darknight wrote:Would make sense if you could stall the wind for higher top speed.
If you mean 'wing' not 'wind', then TEN POINTS TO THE DARK KNIGHT.
Then there's working out what's sinister about it... halfway there guys!
Crabbia wrote:as SZ has said it is incredibly hard to model all the dynamic conditions is a wind tunnel, especially when scaling, but one thing they will never know for sure is how the new tyre characteristics affect the flow. and not just the new size, there will be a new construction of tyre due to the increased weight of the cars. this means different spring rates of the tyre, which again is impossible to model in a wind tunnel.
this is not like last year. mclaren probably poured the money they had allocated to the design and construction of wheel fairing into these pitot tube rakes as a means of continuing development in this area.
Crabbia, most wind tunnel facilities worth their salt keep pitot rakes on hand. It's as fundamental a tool in an aerodynamicists' arsenal as flow viz paint, wool tufts, force balances, a manometer, etc. There is very little outlay in manufacturing them. It's a bunch of tubes on a take, and you can mount that in turn on some sort of traverse if you like. There are more complicated variations on the theme but if someone claims to know your way around basic aerodynamics and thinks that a pitot rake is exoctic... back to school - in any aero introductory text it's the first device mentioned right after Bernoulli's law gets an introduction.
I would contend that a likely scenario runs a bit like this: certain aspects of the flow field between the wing and endplate which end up going around the wheel are highly sensitive to the wheel dimensions (which are new, and subject to scaling effects). Certain aspects of that much are probably sensitive to tyre deformation also. I'd bet the tyres used on the car and those scale model tyres in the wind tunnel probably don't correlate exactly in terms of this aspect of performance, and McLaren simply wants to look to see if there's any difference. Some other teams might have done this differently. McLaren might be looking at aspects a little more advanced than average pressures (something often done in road car development where rotating wheels are concerned).
The usual idiot fanboy pitlane pundits (and I'm talking about those that call themselves 'professionals', not the fans on this board) would probably gain more from having a look at
when the rake moves to get an idea of what conditions they're assessing than to wonder what sort of latest take on an unobtanium flux capacitor it might (not) be. Other teams will probably be looking at
when the rake moves - e.g. are they looking at tyre wake when it's straight ahead running, turning, etc to assess
what information they might be missing out on or
what information McLaren might have missed in development.
