WHERE?ISLAMATRON wrote:it creates 1, maybe 2 more overtaking opportunities per lap for F1 cars.
yes you lose the opportunity hard braking into abby, but you get it back hard braking into 13, although you could get re-passed at 14 if you overdo it into 13... and then a possible opportunity going into the new Brookland if you close up into 13 and get a good run out of 14&15 and catch a good slipstream. If they defend the inside line going into Brooklands you could set up to be in the better line going into Luffield, but that has allways been difficult, new layout or old.Pandamasque wrote:WHERE?ISLAMATRON wrote:it creates 1, maybe 2 more overtaking opportunities per lap for F1 cars.I think it removes 2.
http://en.espnf1.com/f1/motorsport/story/8590.html'It is fast, exciting corners that drivers love. It is what fans love. So, it's illogical not to concentrate on developing the sporting challenge. You end up having to do things you don't want to. It is very frustrating. I have the idea of my perfect, fantasy track and that's not what we are building."
Probably you just can't read.godlameroso wrote:Damon (over the)Hill doesn't know what he's talking about.
Abbey chicane was not fast, or even fast'ish', and in it's place is a flat out right hander. The end of the turn leading onto hangar straight is slightly slower, which makes it a little more challenging in my opinion. Bridge is gone big deal, from what I can tell on the infield there is 2 slow corners, one being more of a breaking zone. The other has a short run to it, so it doesn't require big breaking. The next turn is a tricky high speed left. Then towards the end of the track the slowest corner in the old layout is being made more obtuse with a decreasing radius and hence slightly faster, the last corner is as it was. I don't see how the track is being made slower? Maybe because of a longer lap time but not by it's characteristics.ESPImperium wrote:
He's talking about fast corners. Two very fast corners and one fast-ish chicane is being removed. There are 2 very slow corners in the S3 of the old GP layout. Both of them will be retained +2 new ones added.
