I have always found this concept extremely interesting, even if the company is a little shady.
Along with leaf spring suspension and drum brakes? Or is that overkill on outdated tech?Jersey Tom wrote:358ci, pushrod V8. Carb'd.
The displacement of an engine is the volume of air an engine displaces during one complete engine cycle. For the rotary to complete one cycle, it must do one revolution of the rotor (three shaft revolutions). One revolution of the rotor equals three combustions per rotor, and since Mazda rate their engines by the displacement of one chamber per rotor, the correct displacement will be three times the displacement rated by the method Mazda uses. So the real advantage of the rotary is a big displacement in a small package.autogyro wrote:Can you explain to this poor ancient engineer how you measure the 'swept' volume of the Mazda rotary and come up with 3.9 liters.
The rotary IS used in current road cars, it is just that most cars still use 19th century ic technology.
How is a two stroke engine even slightly close to a rotary in minimal moving part? It still wastes power doing a silly dance called reciprocation!
The rotary only uses to much fuel because it burns rich to keep the combustion temperatures down for tip seal reasons, it can burn low octane fuel better because of the spread out flame path. To meet the fueling needs, fit a turbo generator with air fuel injection into the exhaust prior to the turbine. This burns the unburnt fuel and other exhaust gasses at a high enough temperature for fuel efficiency and also recovers energy from the generator.
Oh and before you dimiss rotary valves completely, take a look at the Bristol sleeve valve engine in the sea fury we used to fly. 2800hp, the Napier was also very useful. WW2 vintage of course.
Single cylinder prototype engines were built, there have been several of that kind, but the step from a prototype to a working racing engine is quite long.Carlos wrote:There was a rotary valve engine project, the Bishop Rotary Valve, that almost reached F1 in conjunction with Ilmor, a3 L F1 V10 was actually designed and manufactured, unfortunately the F1 rules changed, Article 1.15 in 2004 I think it was - only allowing poppet valve engines: http://home.people.net.au/~mrbdesign/PD ... echBRV.pdf
There's also a thread on rotary valve engines:
viewtopic.php?f=4&t=3045&hilit=rotary+sleeve+engine
Both well worth reading, if only for reference and F1 historical perspective.
Let me help with the constant comparison between 2 stoke and rotary engines - it's based on the the similarities of both engines using intake exhaust ports rather than poppet valves.
This goes into the 'answer to a question never asked' category of engines. It's just another way to do what the piston engine alreasy is doing without actually improving anything.Giblet wrote:I have always found this concept extremely interesting, even if the company is a little shady.
A big-block Chevy, xpanded to 500 ci, 800 hp with a mammoth-torque from the word go could be one place to begin?Jersey Tom wrote:358ci, pushrod V8. Carb'd.
What is the latest news on that process? Last time we looked there was no industrial size trial unit that could have been scaled up. There was no efficiency in the process. And finally cost was nowhere near to allow commercialization.xpensive wrote:... with the Ethanol-myth crumbling down, metanol from cellulose could be the answer.
WhiteBlue wrote:What is the latest news on that process? Last time we looked there was no industrial size trial unit that could have been scaled up. There was no efficiency in the process. And finally cost was nowhere near to allow commercialization.xpensive wrote:... with the Ethanol-myth crumbling down, metanol from cellulose could be the answer.
A good point of comparison would be the natural gas industry using biological sources like agricultural and urban organic waste. They have some respectable figures which would be natural for comparison.
Have a look at Schmack AG. They are a good representative. Is there a company that sells methanol from cellulose plants which would be a comparable source of financial and engineering data?
It's ethanol that is made from cellulose. The process efficiency is high compared to traditional ethanol production but so far only small scale.WhiteBlue wrote:What is the latest news on that process? Last time we looked there was no industrial size trial unit that could have been scaled up. There was no efficiency in the process. And finally cost was nowhere near to allow commercialization.xpensive wrote:... with the Ethanol-myth crumbling down, metanol from cellulose could be the answer.
I think you're referring to the Champ Car (CART) engine specification that was used until the demise of Champ Car. In the good ole days... Ford (Cosworth) Mercedes (Ilmor) Honda and Toyota fought it out with these engines. At the peak, they were rumored to produce 900+ horsepower, turning 14k rpm (with wire valvesprings). I don't recall what the boost limit was during this time. Oh yea, Chevy ran the Ilmor until Mercedes took over as the branding manufacturer.@ expensive... I seem to remember a 2.65 methanol V8 concept, mildly boosted, producing some 750 BHP?
Power output of at least one engine exceeded 1000 hp, the Ilmor made Mercedes 500I, and some engines saw speeds as high as 17,000 rpm.countersteer wrote:I think you're referring to the Champ Car (CART) engine specification that was used until the demise of Champ Car. In the good ole days... Ford (Cosworth) Mercedes (Ilmor) Honda and Toyota fought it out with these engines. At the peak, they were rumored to produce 900+ horsepower, turning 14k rpm (with wire valvesprings). I don't recall what the boost limit was during this time. Oh yea, Chevy ran the Ilmor until Mercedes took over as the branding manufacturer.@ expensive... I seem to remember a 2.65 methanol V8 concept, mildly boosted, producing some 750 BHP?
