ubrben wrote:This is a bit of a general one, but I'd be interested in people's opinions.
Having done a reasonable bit of data analysis of racing cars and motorcycles in the past few years it's definitely clear that a metric driven approach is often the best way to genuinely learn something. Basic overlays comparing drivers, etc can be useful, but the examples in books often show glaring differences that are rare when dealing with two decent drivers in the same car.
I'd be interested to hear what sort of metrics people have used and opinions in this area.
From a tyre perspective I find slip energy quite useful in quantifying circuits and sometimes drivers. Things like integrating lat and long G seem popular to get a more statistically robust view of track grip level.
I heard a while back that Pi were considering a "metric driven" software tool to complement the more traditional data analysis software. Anyone using databases to record histories of metrics vs. conditions and setup?
Ben
Please explain further what you mean by metrics? Database of absolutes? database of compared multiple signals? "Peak and valley" compared?
And, are you speaking of Pi's tool box software?
"Things like integrating lat and long G seem popular to get a more statistically robust view of track grip level".
IMHO, The G circle measurement is one of several techniques at work to define grip, to refine it further, one would use combinations of steering and Lateral together with the steering signal mathmatically "speed adjusted" (laymans handling graph that is used in "relationship manner" and use of throttle and long G together to define entry (braking/turn in), apex and exit (throttle on) grip.
This is simplistic overview but generally used.
Within this complexity of signals lies, the handling of the car as defined by the limitations of oversteer (easily found and "easier" to be determined to an absolute number value) and understeer (extremely difficult to "hold" to an absolute number as this number varies from driver to driver... one driver's bad understeer is another's neutral, so to speak.
Quite a few data companies have math generated signals computed an IDEAL steering (individual left and right front tire paths) handling graph to further define a car's grip level and further put an absolute understeer number to it. What still makes this a "gray" area, is as mentioned above, as some driver's have abilities to make an ill handling car appear to be neutral and making the calculation no longer an absolute one.
A historical database beyond just absolute numbers and diverging on combinations of signals to achieve a "true" comparative result would definitely be the ticket.
The most powerful analysis is in comparative anaylsis not in absolute number analysis, yet the majority of the DAG's employed are "stuck" in absolute and only using a small percentage of a data system's capability.
Adding an absolute number database to this group will help them a lot.
Though it's the group that does comparitive analysis that will be on the sharp of the stick most of time, yet this group is a small group in number as it's not an easily acquired skill. It's not the absolute number that's important in how this analysis is done, yet it's most effective. I don't even know where to begin to define a database for this, or if it's possible, but it would be a huge database and if it could be done, would be most effective, in terms of helping along analysis.
Yet, there's even one more data technique that is by far the strongest one (that I'm aware of) and one that separates the driver input to the car, car's input to the driver, car's input to the track, the car's response from the track and finally the driver's input because of the track.
This technique is highly intensive in use of signals and combinations of them. Some data systems software programs are incapable of this type of analysis (due to their programming design) and actually I have used only three that are capable of it. It encompasses the above two techniques with a third, and you can imagine the results from this, by not being "blurred" by the combinations of the driver, the car and the race track. IMHO, this is the future of data acquisition and yes, as you mentioned, a historical database would fit this to a tee.
Now, if you can make a database that one could extract a similar type of corner in radius, incline, banking and grip level as a process input and snip the data from the lap in this way. And paste it together with another race tracks similar corner to form an imaginary track similar to the track your at, you would revelotionize the industry. But maybe that's asking too much.
"Driving a car as fast as possible (in a race) is all about maintaining the highest possible acceleration level in the appropriate direction." Peter Wright,Techical Director, Team Lotus
