A13EX_f wrote:1 set of paddles were for gear shift the others were for changing the torque map or something similar
Ding Ding, finally someone who got it correctly, McL starting using it a couple years ago to change "torque"/engine maps, 1 interesting feature about how it was constructed as that the driver could change the engine map and the gear simultaneously while clicking only 1 lever, or it could be done independently.
It was introduced with the TC ban in order to help the drivers put the power down in low speed corners I believe.
It may have been for torque settings in the past but it may be for fuel settings this year, although changing the fuel settings with every gear shift seems quite silly, but that may be what they were doing with the "torque" maps... really you can only change fuel or timing to affect the torque output.
