wesley123 wrote:actually i think it is jsut a think to brag about, that they can drift without the use of the steering wheel. It is dangerous as you do not have any control of the cars movements, though you still have in some sort.
What i believe is that the drifters control their drifts by using the clutch, to get out of the drift they simply lift the throttle.
On the island of Cyprus on one section of a rally in the Mountains, I drove an Escort Mexico down hill for over five miles in one continual drift from left to right.
On each hairpin. I let go of the wheel after provoking it to spin to the other lock before gripping it again. Perfect loose surface road with perfect rear wheel drive car.
Using the clutch would simply reduce the control available from the throttle and put undue wear on transmission components.
Drifting can be fast, it depends on the road surface and many other variables.
Giblet is right on smooth surfaces the less drift the more speed but even that depends on a balance between corner entry and exit speeds.
