could creuat's hydraulic suspension tech be applied to grand prix cars? would it result in a detriment to or improvement in handling/grip?
http://www.creuat.com
You've understood it right. It sure looks like hydraulic anti roll system but those could be real shocks with valves not just pistons.DaveKillens wrote:Manchild, from the description I'm assuming the left hydraulic cylinder is connected to the left front suspension, and the right cylinder to the right front. Nice concept, but isn't that basically a hydraulic representation of an anti-roll system? The same job can be done with a conventional mechanical system..
Something like giving "hint" to rear wheel what to expect since front wheel has already dealt with bump? I thought about that but I think that slow bumps are less of the problem than stability in high speed corners.DaveKillens wrote:But if that left cylinder was connected to the left rear suspension, and the right cylinder to the right front (and a second, independent system connecting right rear and left front), then it gets interesting.
