Giblet wrote:Raptor22 wrote:Giblet wrote:Easier, harder, whatever, it doesn't remain stagnant.
Why is it on the left hand side do you think? Why not the right or center? Why not a NACA duct then?
Because by ramming air into the cockpit you can avoid much of the turbulence in this area. Now there is a steady but slow flow through the cockpit that exits around the driver and is picked up by the faster moving flow going over and aroudn the cockpit.
Its position is not in the centre because it would blind side teh driver. It can be mounted left or right depending on whether the track runs clockwise or anticlock wise and therefore has more right hand bends or left hand bends.
they could have had to move the inlet for the driver cooling because their nose cone is very thin at the leading edge and the inlet could interfere with the undernose splitter by relieving the high pressure there.
Why would they do so much testing for driver cooling? They don't need the extra cooling, the drivers have been dealing with it for years, and are not going to suddenly decide to open up the cockpit with a snorkel. When they drivers are too hot, they sweat, take a drink, or roll up their glove cuffs.
This is being over-thought.
While they were screwing with the snorkel, they were also screwing with the size of the secondary upper inlet in the intake above the drivers head. hmmmmm.
We know the blown wing slot is fed by that engine cover shark fin, as mclaren said, "it's not how it looks, it's what it does." hmmm.
We also can figure, that if the effect of this system is to make the wing less effective at speed (not just stall it, which is an extreme end of what can be done), then that effect needs to be unused at low speeds. hmmmmmmmmm.
Since no mechanical device can be used, as that is active aero, then it must be manipulated by the driver doing something, that uses no cables, or hydraulics, or electronics. hmmmmmmmm.
Maybe cooling after all, but in a sport where they paint the logos on because stickers cause too much drag and turbulence, I doubt a tall ugly snorkel for cooling when they are other means to get the air in, there, to coddle a driver who needs no coddling.
I like saying hmmmmm though
Nobody can know for sure, but I look forward to possibly saying I told you so when the system comes to light.
I also look forward to saying "Oh well, you were right, live and learn" if I am wrong.
