Will it work with pressures close to atmospheric?
Also, as I said before it should be very reliable, and not affected much by, say, yaw conditions, car ahead etc. You don't want "stall system" to engage when you're in the corner.
Would also be interesting to know how such a system would be affected by turbulence - both in general and when following another car.timbo wrote:Will it work with pressures close to atmospheric?
And how it might deal with potentially large wind speed variations. If there's a 20mph breeze blowing across the track you're potentially asking this thing to do its thing at two different points on the track with 40mph difference in wind speed.myurr wrote:Would also be interesting to know how such a system would be affected by turbulence - both in general and when following another car.timbo wrote:Will it work with pressures close to atmospheric?
All right, calm down now, Pup. I agree that a number of good qualitative arguments have been given and some further quantitative arguments would be required to differentiate between them. Unfortunately, because we don't know the configuration of the wing or the blowing system, any results from CFD are still just conjecture. I'm also sure we don't have the time to validate our models properly, so I don't think we can reach the true answer here, especially for the MP25 wing. Still, an attempt at simulating the wing in (partial) stall to see if drag could be reduced would be widely appreciated I'm sure.Pup wrote:You guys let me know when you're ready to approach this issue with any sense of order.
OK, I'll just come back when the unicorns are gone.
forty-two, it's a difficult one to answer, this, because a number of arguments are pushing for a stall which will reduce the drag of the wing. I don't know if, by the same method, you could increase the severity of that stall to act as an air brake.forty-two wrote:Does anyone think that there's even the most remote chance that what we are looking at here is actually there as an air brake?
How does the pulse get supplied with the knee business? If it's an on/off type system, then there will be a continuous flow (to C1) or not, right? Or is there a different setup?tok-tokkie wrote:Wiki on fluidics http://en.wikipedia.org/wiki/Fluidics
It includes this diagram of a fluidic amplifier but I would call it a flip-flop valve.
A pulse to the side port C1 causes the flow to flip across to outlet O2 etc...
The alternate air could go to the oil cooler and exit the fin to the rear. If there were a pipe in the cockpit with a hole or flap cut out of it so snorkel air could escape, force from a knee seals this pipe and air pressure enters a version of this chamber at C.horse wrote:How does the pulse get supplied with the knee business? If it's an on/off type system, then there will be a continuous flow (to C1) or not, right? Or is there a different setup?tok-tokkie wrote:Wiki on fluidics http://en.wikipedia.org/wiki/Fluidics
Where will the alternative output go? Into the airbox?
Yes !!!tok-tokkie wrote:Wiki on fluidics http://en.wikipedia.org/wiki/Fluidics
Awww the 'toys' are gonna come out. I think it won't be declared illegal, though.pipex wrote:Confirmation of the stalling wing theory?
http://www.telegraph.co.uk/sport/motors ... um=twitter
But that gives a continuous flow to C, whereas the switch works with a pulse, right, not a continuous flow.Shaddock wrote:If there were a pipe in the cockpit with a hole or flap cut out of it so snorkel air could escape, force from a knee seals this pipe and air pressure enters a version of this chamber at C.
No reason you couldn't use a multi chambered/staged device to overcome that problem. If you shape the chamber so the rear is the default exit, then the snorkel air pressure will just move the airlflow across to the oil cooler when needed.Shrieker wrote:This IS how I imagined it would work right after reading SLC's first post about an operated system !tok-tokkie wrote:Wiki on fluidics http://en.wikipedia.org/wiki/Fluidics
Great Stuff !!! + Props =D>
The stream entering the control ports may be much weaker than the stream being deflected
