jason.parker.86 wrote:I am no "valve" expert, nor am I any type of expert, but it is possible to get vales that open under pressure. Take a standard swing / check valve that you use on your toilet system. After a certain amount of pressure, it will open. The idea is that it stops backflow, thus creating a one way street, stopping any water coming the other way.
So is it not within the rules to have a valve that opens up under x PSI / BAR? I do not know if this would be against the rules, but I cant see why this would be any different from Ferrari's flexible wing, which I believe was banned?
McLaren must be very confident of the legality of the wing, maybe someone can explain what the difference is between this wing and Ferrari's flexible wing?
Moving parts affecting the aero are banned. A valve with physical moving parts would be clearly illegal whether actively or passively controlled, the same way the flexi-wings were. On the other side, a valve with no moving parts, like those fluidic valves would be legal (really people, go back to read past posts, in this case in page 113). One could also consider legal (maybe) things where the moving parts are not considered part of the aero, only that pretty much leaves one with the driver as the only possible moving part.
Just to remind everybody of the problem with a fully passive system (which would still be a nifty engineering concept): if you stall the wing (totally or partially) above a certain speed, you also lose your downforce at the beginning of the breaking area, and then when the downforce comes back it would be difficult to not lock the wheels.
Of course, as always that is a case of balance. Probably some straights are long enough that the greater straight speed wuold compensate for the longer braking area.
Another take on this would be if the system is really such a compromise that you don't win any extra lap time, only straight line speed at the cost of braking capacity. Such a car would still be a strategic asset, if you can slipstream but the other cars effectively can't slipstream you, as you have lower drag anyways. Overtaking/defending from such a car would be a total nightmare.
Rivals, not enemies.
