Belatti wrote:Back on topic, Im rather new to the Race/Data Engineer world and till now Im a bit reluctant to Data Logging Metrics, so I have not established any of my own.
I prefer to break down the data in "events" for key parts of the track to analyze them.
For example, a key part of the track would be corner N1.
The events here would be:
1. Straight line braking
2. Braking and steering input begining (corner entry)
3. Steering and throttle begining or coasting (apex)
4. Any steering/throttle/brake disruption (apex)
5. Steering return and full throttle back (corner exit)
Thats no analyze a particular driver and help him out.
To make a fast comparison of drivers of course I´ll have to design my own metrics.
While there are many things that make up a driver's fastest lap, there are two things that stand out that if improved the drivers will go even faster. Those are A) time spent at full throttle B) using the steering wheel as little as possible.
To track these... a histogram of throttle involving three or four bins, so that you end up with a bin of throttle >80% to 100%
Steering use... Dev*Steering.... will put the steering wheel into a velocity. The lower the velocity of the steering, the better the car is, especially steering use at entry and when full throttle is struck.
In your driver's case, the majority of the problems at this track are somewhere around half throttle where most of the steering input (velocities) are occurring. Even a slight reduction of this will account for a faster lap speed.
Driver's technique can be ground down into basic types. 1)Those driver's who need the car to rotate for them (tend to like an oversteering car...and.. 2)those driver's who rotate the car around any problems (read understeer) (this driver will tend towards a slight understeer for confidence in fast corners)and utilize his ability to rotate around it.
The direction of setup will differ between these two groups, almost in an opposite direction.
An excellent question for these two groups of drivers is as follows...Which is faster to them (pointed at the driving) through a fast corner..slight oversteer or slight understeer? If the answer is O/S ...ask the following question...
If your going through the fast corner, and you experience O/S, will you attempt to go even faster on the next lap?.... unless he's nuts and has a lot of money for crash damage..most will answer no.
Replace O/S with slight U/S, and ask the same question again? 9 times out of ten, the answer will be yes, they will push it the following lap.
Which condition is more confident inspiring? Which one is actually a faster sub-par handling condition?
Just maybe you may be able to convince the driver to try a different mentality approach to the handling of the car...understeer, can become a friend rather than the FOE that it is now....
Most of the time, if your driver has come from a career in karting,
understeer..even the slightest bit.. will be a very bad thing to the driver. They tend to like a bit of O/S. They "believe" it's faster. Especially if the driver is new to cars. Even roll will bother them, as roll in a kart means the end of the kart that's rolling is going to give up. ...Just the opposite "effect" in a car.
One technique I have found to "cure" this "karting" problem, is force the driver to spend a day driving the car with A) varying amounts of U/S B) disconnect the sway bars, both and then just the rear...
Just remember that a driver's ego is fragile
when it comes to his driving and your rear end is not in the car. So when describing "problems" that you see in data, DON"T ever suggest or recommend a driving technique change but rather blame the car, ask about the car, not him and leave it on his shoulders to figure out it's him and your life/career in racing data analysis will be a calmer one and hopefully a long lasting one....
want a short career in analysis? ..start teaching your driver how to drive from your laptop.... you will be the first one he'll want to get rid of... [-X
as always, IMHO
"Driving a car as fast as possible (in a race) is all about maintaining the highest possible acceleration level in the appropriate direction." Peter Wright,Techical Director, Team Lotus
