Pandamasque wrote:I think FIA should act ASAP because they might just as well award points for qualifying and let them go home afterwards. Everyone knew that Webber's pace was as good as Vettel's and that Ferraris were catching Vettel at some point in the race, BUT COULDN'T USE THE ADVANTAGE due to overheating, loss of DF/punishing the tires in the wake of the car in front.
EDIT: added the missing bit in CAPS
Now it makes more sense.Pandamasque wrote:I accidentally removed a phrase while posting.Pandamasque wrote:I think FIA should act ASAP because they might just as well award points for qualifying and let them go home afterwards. Everyone knew that Webber's pace was as good as Vettel's and that Ferraris were catching Vettel at some point in the race, BUT COULDN'T USE THE ADVANTAGE due to overheating, loss of DF/punishing the tires in the wake of the car in front.
You mean other than the fact that the cars spend the bulk of the race with upwards of 100kg more weight to pull than in previous years? Basically 15% more weight for 2/3 of the race.WhiteBlue wrote:There is nothing substantially different this season in engine and gear box rules to the last which saw thrilling races. This shows how little sense the endurance argument makes.manchild wrote:No matter what the rest of the rules are, as long as the engines and gearboxes must be preserved for next race(s), and as long as the pit stops for any reason are mandatory, there will be no racing.
Thanks for clarification. What we have in 2010 are old spec. engines and gearboxes, that are expected to push much heavier cars for 5 races. No one has the clue if they'll be able to do do it even at this endurance level.Rob W wrote:..You mean other than the fact that the cars spend the bulk of the race with upwards of 100kg more weight to pull than in previous years? Basically 15% more weight for 2/3 of the race.
Sebp wrote:I say scrap the whole book of regulations!!
The only rules I would impose are these:
1.) Power output limit of, say 750 bhp.
2.) Budget cap of 50m $ a year or even less.
3.) Safety stuff (obviously).
4.) Some eco/green stuff (50% of one years car has to be incorporated into the next model)
The numbers are up for debate.
So: no weight limit, no stupid banning true innovations, possibility of different motor concepts (turbos, diesels, turbines, you name it), active suspension, ground effect, active aero (driver controlled of course)...
Imagine how different the cars would look and race!
I'm only dreaming of course.
Can you imagine an F1 team like Ferrari or McLaren following the spirit of the budget cap rule? We're talking about ones that can develop their engines during the engine freeze, using airfoils as a part of a braking system etc etc etc.Sebp wrote:With a limited budget teams would be forced to concentrate on the technology they think would give them the biggest advantage. They couldn't develop every aspect of the car in as much detail as they would like.
I tend to think (or dream) on the same lines. F1 regulations should be written in a couple of A4 sheets. I guess that more technical freedom would help more radical innovation in the cars. And innovation is not something you buy with money, so there wouldn't be a need for a budget cap, which in my view is almost impossible to enforce. No need to limit power if you can limit the amount of energy (fuel for example) a car can carry and use during a race, encouraging the development of more efficient and environmentally friendly technologies that could be passed on to road cars (not the other way round).Sebp wrote:I say scrap the whole book of regulations!!
