Oh dearOgami musashi wrote:That doesn't change the fact be it a DF car or not when you corner if the lateral force tyres can produce is exceeded the car will slip the same way.autogyro wrote:There is a high vertical (DF) acting on the whole car and the suspension of the car is totaly compromised for its use.
Of course a high DF car handles differently to a non DF car.
I cannot understand how anyone can ignore this.
There's no "rail" cornering with a DF car; There's no "less limit cornering" neither, the physics are exactly the same.
What changes is that because you corner faster you can't overshoot tyre's limit as much as with a slower car because if you do you'll end up in the wall.
If you are cornering faster in a high DF car and the tyres only break away at this high speed, then the tyres are working totaly differently than the tyres on a non DF car where the tyres break away at a far lower speed.
Of course physics does not change, god I wish we could alter that!
Everything on a high DF car works differently precisely because it is a high DF car.
