The problem was already here last year, this year it is simply because the front tyres have less grip; Again, the only relevance to aero problem is the distance you can follow someone. And that distance is like last year if not better.Pandamasque wrote:It is surely not as close as last year. Also the overheating problem is more evident. Especially more than in pre 09 formula. It seems like the 'central heating' at the back of these cars (RB6, STR5 being the most obvious cases) is designed to create overheating problems for the car behind.Ogami musashi wrote:It has always been the same. Again physics do not change; The question is the distance, and the distance is shorter this year, so more overtaking opportunities.Pandamasque wrote: Really? I though they had to fall back to avoid increased tire wear and engine overheating.
I agree with you that some factors may favor that, but again physics are physic, whatever the grip of the following car (if we talk about leading cars, that is cars with not so much differences in grip) if aero were that worse, they wouldn't have overtake; They did.
Please watch a 2008 race a see the distance between cars.
IMO, the biggest improvement in overtaking after '08 comes from the slick tires, that seem to be more manageable. We've seen some drivers getting away with powersliding out of the corners.
Drivers quotes are drivers quotes, not precise measurements.
