+1 Machin
F1 cannot afford to loose its sponsors and it will if it does not clean up its act.
The tyre support situation shows the start of this inevitable decline, which will continue unless major changes are made.
That is comparing apples and bananas. F1 is not comparable to global flying. One is very much a necessity the other is entertainment.WhiteBlue wrote:
That is comparing apples with bananas. F1 is a show that is selling advertising. In order to produce the show world wide and attract advertising sponsors it must expend a transport energy budget which can be discussed in comparison with other forms of entertainment with similar global advertising function (Olympics, Soccer World Cup). I don't think that F1 will look any worse considering that hundreds of millions of people watch it on TV who do not spend significant energy to do so.
All your points cannot excuse the fact that F1 cars as a showpiece and pinnacle of engineering do not make an effort to save carbon emissions as pretty much every other means of transportation does. Aircraft are even more high tech and they continue to provide better and safer service at lower fuel consumption with every generation.
Global warming will happen irrespective of what F1 does. However, if you must be 'green' set a proper challenge. Say, each car must compete in the race with no more than 50 litres of fuel. That's 50 litres for 300km. Everything else is free. Go ahead and engineer. But don't try to pretend that 20-odd F1 car doing 27mpg instead of 4mpg for 19 weekends is 'green'.Global warming is every bodies problem and if you are in the spot light and give a rats ass it looks bad. F1 should make the effort at fuel saving that the FiA has set out to achieve in 2008. At that time a target was set to reduce F1 car's fuel consumption by 50% in eight years. Two years are gone and nothing has changed. It is now time to do something.
People hereabouts have been suggesting lots of ways to reduce costs etc. in F1. Here's one. How about banning advertising on the cars? Bang! You've just cut the budgets quite consideably.autogyro wrote:+1 Machin
I havn't compared it to global flying. I have compared the transport budget of F1 to that of the soccer world cup or the olympics. Those would be comparable events in terms of global sporting shows televised for advertising. Those events require a lot more air lift and ground transport with the respective carbon footprint.Just_a_fan wrote: F1 is not comparable to global flying. One is very much a necessity the other is entertainment.
WhiteBlue wrote:I havn't compared it to global flying.Just_a_fan wrote: F1 is not comparable to global flying. One is very much a necessity the other is entertainment.
Wrong. I can understand that reducing fuel consumption can be used to change the show e.g. by giving designers scope to be clever. I don't understand why it needs to be done in a way that pretends that F1 is green.I have compared the transport budget of F1 to that of the soccer world cup or the olympics. Those would be comparable events in terms of global sporting shows televised for advertising. Those events require a lot more air lift and ground transport with the respective carbon footprint.
You cannot understand why fuel consumption in F1 cars matter enough to make an effort to reduce it while maintaining the show.
I'm not against reduced fuel useage as part of the engineering challenge. What I'm against is trying to make out the F1 is somehow green because of it.Fine there will always be folks who disagree with any proposal even those sensible as hell. Keep your opinion. I will not try to convince someone who doesn't listen.
My analysis of the situation is echoed by Paddy Lowe in an interview today on Autosport:Just_a_fan wrote:And as for not listening, it's no different to your continued call for limited downforce even when others have suggested the course is flawed
Here we have a very competent man who was actually a leading force in the OWG saying exactly what I have said.Paddy Lowe wrote:Q. Have the rear-wing changes introduced for 2009 really worked in terms of increasing overtaking?
PL: I think things are getting worse in terms how the overtaking working group, which set out the rules for 2009, intended. Principally this is because the cars are generating much more downforce out of the floors than was ever envisaged. A lot is driven by the opportunity we get from the double diffusers. One of the intentions of the OWG package was that the downforce generated by the floor would be much lower, and this would help overtaking. Firstly, if you have less downforce to begin with, then you lose less in the wake.
Secondly, generating downforce the floor creates a very bad wake for the following car. Downforce now is approaching where it was in 2008 in terms of levels, and at the same time we have slick tyres now against grooved tyres, so it has escalated. What we've agreed for 2011 is to ban double diffusers and reduce the height of the diffuser exit, which will reduce the amount of floor-generated downforce, which will be better for following cars. We are looking at whether even that is sufficient. I think what we've agreed is that we're going in the right direction with OWG.
Sorry just a fan but if you want to bath in the reflected glory of the fastest F1 cars in the world you will have to retrace your steps away from the backward step of the high DF current cars and go back in time, probably to the turbo era when the sport was worth watching.Just_a_fan wrote:autogyro wrote:+1 Machin
Seriously, do you really think that Vodafone or Santander give a flying fig whether the cars do 4mpg or 8mpg? Of course not! F1 is about glamour and excess not frugality. They are in F1 because of the reflected glory of the fastest racing cars in the world being driven by some of the best drivers in the world appeals to the minds of 'the great unwashed' i.e. you and me. They know that we watch and thus they pay to advertise. Will you stop watching because the cars only do 4mpg instead of 8mpg?
Nostalgia isn't what it once was.autogyro wrote:Sorry just a fan but if you want to bath in the reflected glory of the fastest F1 cars in the world you will have to retrace your steps away from the backward step of the high DF current cars and go back in time, probably to the turbo era when the sport was worth watching.Just_a_fan wrote:autogyro wrote:+1 Machin
This was before it was high jacked by aero nurds with vested interest.
The 'men' who used to be involved got to bored to bother ol son.
And this is a basic misunderstanding. I am not supporting a downforce limit, I find the idea ridiculous.WhiteBlue wrote:And this is the basic misconception. If downforce is limited there is no need to make any restrictions to aero configurations. Teams will automatically find the one which is best for the performance. The rules do noit have to be changed in the future to adjust to performance increases. The development will automatically reduce drag and turbulence for any config that is more efficient.Scotracer wrote:What we need is for the OWG to get back in the wind tunnel and try out some different programmes (i.e. more underfloor aero; less total aero; removal of wings etc etc). Enough bloody speculation.
You are not telling anything new. The last thing we need is another round of OWG delays. Last time they have only been used as an excuse to shoot down the downforce limit. Even P. Lowe from the OWG says that DDDs were the wrong thing to do and that too much downforce is the problem. He doesn't think that diffusor downforce is any more beneficial on wake turbulences than wing downforce. We now have as much downforce as in 2008. So should we give the tricky Dickies of F1 yet another opportunity to define aero rules which supposedly cut downforce but in reality will never do this? The aero guys have played everyone for sucker much too long!Scotracer wrote:And this is a basic misunderstanding. I am not supporting a downforce limit, I find the idea ridiculous.WhiteBlue wrote:And this is the basic misconception. If downforce is limited there is no need to make any restrictions to aero configurations. Teams will automatically find the one which is best for the performance. The rules do noit have to be changed in the future to adjust to performance increases. The development will automatically reduce drag and turbulence for any config that is more efficient.Scotracer wrote:What we need is for the OWG to get back in the wind tunnel and try out some different programmes (i.e. more underfloor aero; less total aero; removal of wings etc etc). Enough bloody speculation.
