Renault R30
madly
madly
Re: Renault R30
Kubica said in Polish press after P2 that "[..] they have some problems and team is considering not to use new floor." But: "new front wing improves slightly car balance. it's not a big deal but a consecutive step in a good direction."
spaman
Re: Renault R30
How could the new floor cause any problems? In this case it seems to be a major misdevelopement.
madly
madly
Re: Renault R30
spaman wrote:How could the new floor cause any problems? In this case it seems to be a major misdevelopement.
Due lack of time I shortened RK answer probably changing "slightly" meaning. My English is far from ideal, sorry. Another attempt ti translate RK answer.
Q: How do the new improvements made to the R30 model?
RK: Here we have some new parts in the car. Unfortunately we had some minor problems morning. I do not know what will be the final decision, but I think we will no more use a new floor. As for the new wing, it had improved the car a little balance. This is not no big deal, but it's another step in the right direction.
R30 floor has a big importance in DD efficiency, so if simulations doesn't agree with real, then it could be a step back instead of improvement. Isn't?
raymondu999
Re: Renault R30
Maybe they underestimated the F-duct advantage and now they're rushing to build it?
失败者找理由,成功者找方法
madly
madly
Re: Renault R30
raymondu999 wrote:Maybe they underestimated the F-duct advantage and now they're rushing to build it?
Probably or R30 is so compact, that it is too difficult or costly (time and effort) for this particular construction to implement such a solution?
Diego F1
Diego F1
Re: Renault R30
Agree. They adopted a very agressive developement strategy in order to raise the team's level. But there is always the risk of making big but wrong steps. Still to early to know if this a wrong or a good one.
madly
madly
Re: Renault R30
From F1.com
zgred
Re: Renault R30
Pierce89
60
Re: Renault R30
zgred wrote:Image
SHAGGED!!!
ARX_RNLT
ARX_RNLT
Re: Renault R30
What's this?
Re: Renault R30
vortex generators, waht their function is, i dont know
dnomdec
dnomdec
Re: Renault R30
Has anyone found pictures of the "new floor" Kubica is talking about? I got the impression that it is not the same spec as the one on Petrov's car sprayed by the fire extinguisher, but I couldn't see what's new in the pictures I found.
Re: Renault R30
Show us the pictures you fonud
ARX_RNLT
ARX_RNLT
Re: Renault R30
ARX_RNLT wrote:What's this?
Have noticed that those where only on petrov's car... It's something similar like on R25/R26 car - those are not forbiden?
mx_tifoso
mx_tifoso
Re: Renault R30
Images being posted twice in the same page, thank you for that guys. :)
ARX_RNLT, you can just refer to the 'vortex generators' instead of posting the entire image again. We will know what you're talking about.
