Hi all mates!!
Reali coool car!! But I have big question)))
Ehat is new part a little bit upper then front upper wishbones??
It comes from upper part of Connecting point (wheel and upper front wishbones)
I think this is illegal too, but in an additional aspect, because I thought you could only mount wings to 'suspended' parts of the car. There's a huge advantage to attaching a wing directly to the wheel hub.isnt there some regulation against "moving aero devices"? Wouldnt that be a violation if it rotates with the brake assembly?
That's the answer. They have designed it in order to fall inside the "brake air intake" area. This way, it is not illegal. Concerning the spirit of the law, true is that brake intakes have extensively been used in the past in conjunction with front wings to provide downforce, so that's not new.Its overall width is 12cm, the maximum allowed for brake air intakes
It doesnt rotate with the wheels assembly...it stays static. Also its not an aero-device its just a brake device shaped for optimum aerodynamics...like any other cooling duct.isnt there some regulation against "moving aero devices"? Wouldnt that be a violation if it rotates with the brake assembly?
I don't see how this cannot be considered an aerodynamic device. It obviously helps improve the grip. It can only do this by working the air flowing past it. It is using the air to create grip.As the structure turns with the wheel it also acts as a mobile winglet, providing a small but constant increase in front grip.
